Cobalt Shift Knob
Old Oct 22, 2008 | 09:57 PM
sikcess's Avatar
Cobalt Shift Knob
I just bought a '06 Cobalt SS/SC and I am trying to replace the shift with a TWM knob. Has anyone come across how to take off the stock knob?
Old Oct 22, 2008 | 09:58 PM
BLAZIN07SS's Avatar
I'm too JDM for you
the stock knob is pressed on, it doesnt get screwed on, im pretty sure you can change it unless you change the shifter
Old Oct 22, 2008 | 11:10 PM
sikcess's Avatar
any ideas on how to get it off?
Old Oct 23, 2008 | 02:41 PM
Try2k's Avatar
The cap on top with the numbers on it unclips and there is a screw underneath it.
Old Oct 23, 2008 | 04:23 PM
ShortStack's Avatar
try2k = correct.
Old Oct 23, 2008 | 05:46 PM
sikcess's Avatar
do you know any good sites to buy new shift knobs? not and oem knob just ones that look better and are compatible.
Old Oct 23, 2008 | 06:35 PM
Try2k's Avatar
I don't think there is anything you can do besides ghetto rig something up... Doubt you'd want to do that.
Why are you against an aftermarket short shifter? It makes the shifts feel much more solid. They aren't too expensive either.
Old Oct 23, 2008 | 06:37 PM
slowswap's Avatar
Shortened shifters cause increased forces getting exerted on the shift forks and syncros which will wear them selves out quicker. Its a valid reason for not wanting a new one.
Old Oct 23, 2008 | 06:42 PM
miked5426's Avatar
just wait until about 30k miles and itll pop off by it self when you shift!! hahahaha. thats what mine did
Old Oct 23, 2008 | 07:37 PM
tobz's Avatar
A shorter shifter is not going to apply more force into the shift forks.
The shifter is a lever. The longer it is, the less input force is needed for a given output force. The shorter it is, the *more* input force is needed for a given output force. That is the basis of the lever.
As far as syncromeshes getting damaged, I have a limited knowledge of their operation so I wouldn't feel comfortable commenting on your statement about them. However, being as your statement is incorrect, I would have to follow that your statement about the syncromeshes is also incorrect.
Old Oct 23, 2008 | 08:36 PM
Try2k's Avatar
A shortened shifter is different from a short shifter. Distance traveled is different than shifter height.
Not arguing with anybody just stating
Old Oct 23, 2008 | 08:47 PM
BlilBT's Avatar
Search is your friend I made this awhile ago https://www.cobaltss.net/forums/show...removal&page=3
Old Oct 23, 2008 | 09:19 PM
tobz's Avatar
True, I didn't totally read through. My comment would be to a physically shortened shifter lever.
Old Oct 24, 2008 | 01:36 PM
slowswap's Avatar
Sorry I meant to say short shifter. A shortened shifter will still increase the forces though when banging the gears, but not as much as a short shifter.
Old Oct 24, 2008 | 04:44 PM
sikcess's Avatar
thanks everyone for the help. i am goin to put in a short throw shifter. a whole new unit with the reverse lock and all.
brett.higgins3
Sep 24, 2015 09:51 AM
The Rookie24
Sep 20, 2015 04:33 PM
roadrunner132
Sep 19, 2015 04:35 PM
SS_2009_TC
Sep 11, 2015 05:41 PM
