runs like crap
Old Oct 18, 2008 | 12:36 PM
05 red ss's Avatar
runs like crap
i have a 05ss/sc with a 2.5 pully 60# injectors i get 15 pounds of boost and at around 4000rpm the car sputters and doesnt want to get speed
Old Oct 18, 2008 | 12:39 PM
drew1991sf's Avatar
dang lol i get 15lbs of boost with just my set-up
Old Oct 18, 2008 | 12:40 PM
BLAZIN07SS's Avatar
I'm too JDM for you
doesnt sound good. throwing any engine codes? sounds like a subuaru? did you have any cooling mods?
Old Oct 18, 2008 | 01:48 PM
Maxim_X's Avatar
Could be a lot of things.
Maybe some more info like on alll of your mods. When this started happening and how it was tuned could help.
Old Oct 18, 2008 | 04:15 PM
corky3's Avatar
it could be throwning a code without actually showing you any lights?
Old Oct 18, 2008 | 04:17 PM
Perfect.disguise's Avatar
No exhaust or cooling mods?
Old Oct 18, 2008 | 06:17 PM
05 red ss's Avatar
has megan racing exhaust, intake,was tuned before with a 2.8 with 42#.....fucked up tuned.
Old Oct 18, 2008 | 06:30 PM
Maxim_X's Avatar
Maybe the fact that he is running 60's on a 42 tune?!?!?
Old Oct 18, 2008 | 07:00 PM
pjk91's Avatar
check plugs + gap. go copper.
Old Oct 18, 2008 | 08:01 PM
05 red ss's Avatar
i have hp tuners and i have colder plugs ibeen trying 2 get it to run right but i cant plugs are new about 150 miles on them
Old Oct 18, 2008 | 08:18 PM
Hockeyman's Avatar
get someone qualified that can tune you, and get cooling mods before you blow up.
Old Oct 19, 2008 | 05:19 AM
theneelster's Avatar
You should just run no pulley.
No seriously it could be a ton of things.
Yeah...no ****. Why not pull a can off of hpt's site for that setup. I'm not sure if there's a 2.5 setup. I mean...with a 2.5 if you don't have an adjustable tensioner you're going to get belt slip like a **** with the stage 2 belt.
Last edited by theneelster; Oct 19, 2008 at 05:19 AM. Reason: Automerged Doublepost
Old Oct 19, 2008 | 07:13 PM
Karlen89's Avatar
Mine with stage 2 with stock exhaust was running like **** too, hitting really high boost. (17lbs) Found out it was my clogged cat.
I see you say you have an aftermarket exhaust, but I thought Id throw this out there. Good luck finding whats causing it.
Old Oct 19, 2008 | 07:21 PM
Doubletg13's Avatar
i see you mentioned sounds like a subaru...a few weeks ago mine started sounding like that...i took it to the dealer and they couldnt find anything wrong.. im also making like 17lbs of boost with the gm stage 2 setup?
Old Oct 19, 2008 | 07:27 PM
evilgoat's Avatar
probably spark blow out, change the spark plugs and check the gap
Old Oct 19, 2008 | 07:28 PM
an0malous's Avatar
wow i dont even know where to start in this thread lol
Old Oct 19, 2008 | 07:31 PM
Axle Man's Avatar
stop driving ur a car PM fast98 for a tune and plugs. get the 2.5" off and get a 2.8" until u have more supporting mods
Old Oct 19, 2008 | 08:24 PM
05 red ss's Avatar
plugs and gap are fine runs great till 4000and abouve feels like its not getting fuel it has no cat and i have the smaller belt and the adj tensioner
Old Oct 24, 2008 | 05:11 PM
05 red ss's Avatar
Thumbs up
thanks for the info guys i got it running right changed the air fuel ratio and injector settings on hp tuners
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
dennis69
Oct 20, 2015 04:49 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
