Cobalt ss starts and then shuts off
Old Jan 14, 2020 | 09:17 PM
vanno242's Avatar
Engine cranks and starts then dies!
So, i have an '05 cobalt ss/sc. My issue is that when I turn the key in the ignition the car cranks and then starts but then it idles roughly before dying. Even when I press the gas pedal it doesn't/barely responds to it. I've change the purge solenoid, zzp performance coil packs, cleaned the throttle body, changed the fuel lines (they were leaking), got a new maf sensor, new map sensor for the supercharger, I also got a new coolant temp sensor and map sensor that screws in right beneath the fuel rail off to the side.
*Sidenote*: The engine flutters like its struggling for air or fuel before it dies and I'd hear a popping sound from the muffler as it's trying to start. My next thought was to change the fuel filter. It's a brand new fuel pump assembly also.
Any suggestions??!
Old Jan 15, 2020 | 08:32 AM
jdbaugh1's Avatar
Any suggestions??!
Is your check engine light on and did the car run long enough to set any codes? I know you said you replaced MAF and MAP sensor but the symptoms you describe sound a lot like what happens when you unplug the MAF sensor. There's a possibility one of the new electrical components you put on was bad out the box and is giving you trouble or something happened during installation.
vanno242
May 13, 2019 08:28 AM
MrSlickSter06SS
Apr 16, 2013 01:05 PM
MrSlickSter06SS
Mar 23, 2013 05:15 PM
JohnyNFullEffect
May 24, 2009 09:04 AM
ItalianJoe1
Sep 7, 2008 10:22 AM
