Codes from OTTP Rotated mounts?
Old May 20, 2009 | 09:48 PM
Rodimus_Prime's Avatar
Within two days of installing these I'm getting the following codes P0503 and P0300, whats going on here and how can I reduce the vibes, I think thats whats triggering the codes
Old May 20, 2009 | 09:56 PM
Angel's Avatar
Same thing here. Just installed and tripping codes P0300 and another code, cant remember either excessive crankcase pressure or a lean code. I was told that these wouldnt increase the cabin vibration THAT MUCH, but if I have a pop can in the front cupholder it almost bounces itself onto my lap.lol. I really hope these things mabye "break in" or something because for a dd car I can stand this.
Old May 20, 2009 | 09:59 PM
NWAE Cobalt's Avatar
odd..these were supposed to be better then the ttr set lol, sounds like they are WAY worse
also, a p0300 code is a random misfire...
Old May 20, 2009 | 10:00 PM
yea i know what the code is, im just trying to figure out how to get rid of it, otherwise im selling these mounts
Old May 20, 2009 | 10:01 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i have had these mounts on for over 2 months with none of this. obviously the p0300 is random cylinder misfire and p0503 is a vehicle speed sensor. vibes will not trigger those codes
Darkmanx's Avatar
Mounts triggering misfire codes? riiiight
Old May 20, 2009 | 10:02 PM
BLAZIN07SS's Avatar
I'm too JDM for you
no, full poly is horrible. like you dont even understand. ott stage 2's are worlds better than any poly mounts
Old May 20, 2009 | 10:03 PM
Bl4des's Avatar
if you have really bad vibs loosen all you mount and shake you motor then tighten everything back up i barely have any vibs with stage 2 rotated mounts
BLAZIN07SS's Avatar
I'm too JDM for you
x2 it only vibes with the AC on at idle. off idle its fine
Old May 20, 2009 | 10:04 PM
Deathscythe's Avatar
I don't know how you got the 503. Mine have been in for months now and that hasn't shown up. I had the random misfire but that's due to the build and things needing fine tuning.
does anyone get vibes when crossing over 2k rpm? That's when vibes are most noticeable for me.
Old May 20, 2009 | 10:05 PM
doesnt matter any more for me lol, cams and such made it vibe pretty bad anywho lol
i did find though that after installing lightwieght pullies that my vibes almost went away
Old May 20, 2009 | 10:06 PM
Stiner's Avatar
during installation aren't you supposed to not fully tighten the mounts then drive your car for like 5 min to settle eveyrthing in and then fully tighten? did you do that?
Old May 20, 2009 | 10:08 PM
ecotecturbo's Avatar
I have JBP poly trans mounts and engine mount and have never threw a code
Old May 20, 2009 | 10:09 PM
i was about to say lol, if poly is so bad then why havent i thrown i code either lol
Old May 20, 2009 | 10:11 PM
im going to loosen them up tommorow and retighten them , but I dont think its a coincidence that these codes popped up the day after and the tune hasnt been changed for months , never had these codes before
Old May 20, 2009 | 10:20 PM
WickedSS2005's Avatar
If that's the case, my TTR mounts are up for trade Rodimus. What can we work out?
turbaltss's Avatar
How mant times does it take for a cobalt owner to be told for him to understand a misfire code has **** to do with the mounts?
answer: we don't know yet 'cause he keeps on asking
BLAZIN07SS's Avatar
I'm too JDM for you
dude seriously...mounts causing misfire and a VSS code? thats like saying i installed the mounts and got a flat tire the next day! mounts are not going to do anything like that
Old May 20, 2009 | 10:28 PM
Darkmanx's Avatar
Know any good ecotec builders in orlando?
Old May 20, 2009 | 10:31 PM
EXsoccer1921's Avatar
if you do loosen them up. loosen all four and shake it around a bit
Old May 20, 2009 | 10:39 PM
ShortStack's Avatar
Seriously... A mount causing a misfire?
come on.
Old May 20, 2009 | 10:48 PM
apparently from reading other posts on here when i did a search im not the only one
Old May 20, 2009 | 10:50 PM
KillinKrullin's Avatar
hey, if youre sellin, im buying.
Old May 20, 2009 | 10:51 PM
I still don't see how you can get a 503 from the change in mounts.
Old May 20, 2009 | 10:52 PM
i haven't had any problems. just try loosening them all up and then retightening. but don't over tighten the main bolt that goes through the mount so much that the spacer rings and starting to compress
