Codes from OTTP Rotated mounts?
Old May 23, 2009 | 09:16 PM
  #101
joeworkstoohard's Avatar
Originally Posted by stonny9
I have full bwoody mounts and the steering wheel shakes horribly with the a/c on idling and accelerating from a low rpm the whole interior rattles.
sounds like my 2.4 with TTR inserts.
Old May 23, 2009 | 09:20 PM
  #102
Zach06CobaltSC's Avatar
The only time my interior/wheel shakes is when my rpms drop to low when im in 1st gear. Like if my rpms hit 500 when I first let the clutch out and start to hit the gas for a split second when my rpms dip down the dash will shake some. It really isn't a big deal though.
Old May 25, 2009 | 11:29 AM
  #103
Rodimus_Prime's Avatar
A few changes that I made to the fueling tables have helped considerably, its on cold starts that it shakes the most, when its warmed up its fairly normal.
One other interesting thing to note, I actually have less knock shifting. Since my car was stock whenever I shifted there would be a touch of knock as the next gear engauged, this is virtually gone now. Another big change I made was loosening everything shaking it around then retightening but not death grip tight like before.
I'm debating whether or not to put the ingalls back on, I still have a slight touch of wheelhop but not much
Old May 25, 2009 | 01:20 PM
  #104
BLAZIN07SS's Avatar
I'm too JDM for you
if your still gettin hop, check your control arm bushings. mine started hopping again from bad CAB's. they must have been going bad for quite some time because every anti-wheel hop mod i would do, it would work for a little while, then start hopping again. getting the CAB's replaced on thursday
Old May 25, 2009 | 01:32 PM
  #105
im going to get the OTTP ones at some point the spherical ball thingys
Old May 26, 2009 | 08:06 AM
  #106
rallycobalt06's Avatar
i have a set of these in my garage, will be installing them soon (i hope)
Sl0wbaltSS
Nov 21, 2018 11:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
importkiller
Sep 30, 2015 07:18 PM
nathan112i
Sep 30, 2015 07:12 PM
