Come And Go Lean Code
Old Mar 18, 2008 | 10:57 AM
gotboost21's Avatar
I Only Have An Intake On My Car, And Have Had It Since 3k, Now At 15k, The Check Engine Light Goes On And Off, When It Rains...the Code Is System Too Lean Bank One. Any Ideas...
Old Mar 18, 2008 | 10:59 AM
Raven SS's Avatar
u have a wideband?
Old Mar 18, 2008 | 11:02 AM
gotboost21's Avatar
Negative, Just A Check Engine Light
Old Mar 18, 2008 | 11:10 AM
Raven SS's Avatar
i was asking if u had a wideband to verify that u were going lean...a clogged intake from the rain wouldnt cause u to go lean..it would cause rich..
Old Mar 18, 2008 | 11:16 AM
gotboost21's Avatar
Yeah I Dont Know Whats Goin On, But Its Goin To The Rapists (dealer) Today... Which Im Not Happy About
Raven SS's Avatar
is ur intake a k&n because they wont warranty it and blame it on ur intake
Old Mar 18, 2008 | 11:26 AM
thatotherguy's Avatar
you could be sucking alittle water up, when you bought your intake and put it on did you put that oil **** that comes with it??? because beleive it or not that oil can get on your maf senior and throw some codes
Old Mar 18, 2008 | 11:28 AM
gotboost21's Avatar
I Bought The Car At 3k With The Intake On It... Its A Fujita, I Havnt Oiled It
Old Mar 18, 2008 | 11:33 AM
probably the dude before you oiled it so my guess is get a new filter and clean the maf sensor
Old Mar 18, 2008 | 11:34 AM
LS6Rally's Avatar
my K&N dd that to me for a while but it went away after about 4K. dont know what to tell ya bud. good luck
Old Mar 18, 2008 | 06:20 PM
gotboost21's Avatar
so yeah... **** the dealer, action chevrolet and smartdealnetwork (anyone in upstate new york knows who they are). they told me im outta warranty b/c of my intake and thats what is causin my light... even though its not on all the time and i had 12k on it with an intake and no ****** check engine light. this is bullshit
Old Mar 18, 2008 | 06:26 PM
thought's Avatar
what can I say, some are good some are bad. try another dealer, but in the meantime get some MAF cleaner and a new filter w/hydro shield - see if that helps.
Old Mar 18, 2008 | 06:28 PM
gotboost21's Avatar
thats the thing is the light is off now. it cant be the intake
Old Mar 18, 2008 | 07:56 PM
zinner's Avatar
Moderator Alumni
The lean code really doesn't make anything to do with the engine going lean. It's the LTFT going over a +20 value. It's more than likely because of your intake causing the MAF to register less air than is actually entering the engine. This makes the ECU added more fuel and register a lean condition. EIther that or there is a leak in the intake tract.
Old Mar 18, 2008 | 07:59 PM
gotboost21's Avatar
But Why Now And Not 13k Ago? AND WHY ISN'T IT CONSTANT?
Old Mar 18, 2008 | 08:29 PM
zinner's Avatar
Moderator Alumni
Maybe you are at like 18.4 and something put it over that limit of 20.
Old Mar 18, 2008 | 11:10 PM
Sergio's Avatar
Its the bloody intake, always is. Seriously none of the big name manufacturers get the pipe diamater or maf positioning correct.
The gains they post are a missleading too. They dyno the car right after they install it, so naturally the MAF is wrongly measuring less air due to the above issues. So the car leans out and of course its gonna be making more power. Its a scam, they perpously design the MAF placement as such to inflate the gains.
However, the ECU won't be fooled that easily so over time and thanks to the O2 sensors it adjusts the air/fuel ratio to get it back in line with stock. If this correction factor exceeds 20% it throws a CEL.
So not only is it making far less than the advertised power, it could possibly harm your engine.
The stock air box is restrictive no doubt as its made for sound dampening and not performance, but nobody is getting 15hp from an intake - not even close.
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
