couple questions for turbo conversion on lsj
Theres a few pics below that have sensors and tubing that Im not sure what I do with once the supercharger is removed. Can someone let me know what you have done with these on your turbo conversions?
There was a pre-formed hose that went to the superchager from this nipple. From the nipple it goes to the back of the car alongside the fuel line i believe.
As I was removing the supercharger I came across these stumbling blocks and realized that im going to need help with them..
The first pic is your EVAP solenoid. Run a vacuum hose to it from your new intake.
The second pic is your MAP and IAT 2 sensor. You will need this sensor.
The third pic is your blower bypass solenoid. You don't need it, but you will want to delete the code that sets when you remove it.
The plug you circled in the last pic is part of your throttle body. You will definitely need this.
Turbo Johnny
Feb 21, 2019 09:41 AM
