crank no start
Old Nov 1, 2010 | 01:48 PM
utibalt's Avatar
crank no start
well i finally got a dual pass, but now my car wont start..first time after i ran the car with dual pass installed i got about two or three blocks away from my house and all of a sudden a huge cloud of white smoke came from somewhere and then my car died. and my quarter tank of gas turned to empty. it wouldnt start back up right away but i did manage to get it running and back into my garage. later that night i took everything back apart and found coolant in my intake manifold. so then i put everything back and made sure everything looked good with no problems. and when i went to go start my car it wouldn't run. it cranks but it just won't start. i did have two check engine codes on that i cleared like an idiot and did not write them down. they had something to do with fuel.. so i'm thinking it's not getting any fuel..
what to do now? any ideas?
ps i did switch from 2.7" to 2.5" pulley throughout this process.. but why would a pulley change cause a no start?
Old Nov 1, 2010 | 01:55 PM
Chevycobaltss3's Avatar
U didn't replace the o rings for the lamiova cores and they seeped coolant in. U didny propery install the laminova cores. ...
Old Nov 1, 2010 | 03:14 PM
utibalt's Avatar
yeah i figured that much but then after the second time around i made sure it was done correctly, main point here is to figure out why it wont start now? could the coolant that ended up in the manifold damage the engine in some way for it not to start? maybe the cylinders are filled with coolant still?
also i hear the ic pump making noise, never heard that happen before.. i did go by the diagram that zzp has on there site for the hose routing. if i have the hose routing for the dual pass wrong what will happen?
Old Nov 2, 2010 | 12:11 AM
terry11's Avatar
Pull the plugs, clean them, spray carb cleaner in the cylinders and crank it over with the fuel pump relay removed. While your cranking i would also have someone spray carb cleaner into the intake. There is a lot of coolant in your motor. Change your oil as well. If gas can get into the oil from running too rich there is a good possibility you have dexcool in yours. Anyways... Good luck man
Old Nov 3, 2010 | 09:20 PM
utibalt's Avatar
figured it out thanks guys i still have coolant leaking into manifold though. gonna have to replace the gaskets o rings.
dennis69
Oct 20, 2015 04:49 PM
Stuff
Oct 1, 2015 05:47 PM
cw383
Sep 30, 2015 12:41 AM
roth
Sep 26, 2015 12:16 PM
