Crank sensor Relearn?
Old Nov 11, 2010 | 07:58 AM
wRcKLes's Avatar
I want to install my stage 2 kit from OTTP but I don't have the tool needed to do the Crank sensor relearn would it destroy my car if I drove it less then a mile down the road to have the crank sensor relearn done? im trying to save my money by only having to pay a shop for what I need them to do
Old Nov 11, 2010 | 08:35 AM
coopercharge's Avatar
You can see if a local auto parts store has thee GM techII tool, I doubt they will but its worth a shot. Or find someone in your area with HPT or the Trifecta cable and software as these can alse do the CASE Relearn.
Old Nov 11, 2010 | 09:25 AM
wRcKLes's Avatar
so your saying it would be a bad idea to drive it down the road even if I strictly keep it out of boost?
Old Nov 11, 2010 | 09:40 AM
dspeed123's Avatar
You can drive it.
Old Nov 11, 2010 | 10:53 AM
wRcKLes's Avatar
now I just got the car back got the parts installed at a friends place the weird thing is that there is no CEL and no security I had to go though ....any answers?
Old Nov 11, 2010 | 11:04 AM
dspeed123's Avatar
I have questions. Are you sure the PCM was swapped out? If no security relearn was necessary then the PCM was never swapped out. Might want to check and see that he did this and you just don't know about it. The crank relearn code would be present too. Sounds to me like he didn't swap out the PCM. When you ordered did you only order a tune file because your friend has HPTuners? If thats the case then you don't need a security relearn or a crank relearn.
Old Nov 11, 2010 | 11:08 AM
umrdyldo's Avatar
Anyone tried a crank case relearn with a DashHawk?
Old Nov 11, 2010 | 11:35 AM
wRcKLes's Avatar
just called OTTP to verify and they said it could take a few miles for the CEL to actually come on but you should get it done ASAP anyway just to be sure so thats what I just did
you can defentally tell just by looking at the new PCM that it was changed out and I dont think a freind would try to blow my motor like that......and if it was not swaped out me pushing 17 psi i only did one quick second gear pull wouldn't be as smooth as it felt and there would be a CEL after that pull and there is not the parts where changed out
Old Nov 11, 2010 | 11:38 AM
dspeed123's Avatar
Dashhawks don't work with LSJ's.
Old Nov 11, 2010 | 11:40 AM
dspeed123's Avatar
I wasn't trying to say your buddy was trying to screw you, maybe he just forgot to do it. I can tell you that both times I swapped PCM's the crank relearn popped up immediately.
Old Nov 11, 2010 | 12:15 PM
wRcKLes's Avatar
my buddy chris has a balt and his didnt pop up till 30 mins later I already had it doneso everything is straight now and it feels good
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
agentirons
Oct 16, 2015 02:11 AM
Stuff
Oct 1, 2015 05:47 PM
jmelton327
Sep 26, 2015 10:04 PM
