Custom Option B brackets?
Old Jan 9, 2011 | 07:17 PM
ssyellow's Avatar
Hello,
I have the stock coolant tank that I bought and I was wondering if anyone has found some brackets at the local hardware store that would be good for mounting the tank or if they have created their own out of random parts. Any ideas welcome. Thanks in advance.
-Nate
Old Jan 9, 2011 | 08:21 PM
ssyellow's Avatar
Old Jan 9, 2011 | 08:28 PM
glen229's Avatar
stock tank, made a bracket that you cant see from a small alluminum bar 1" wide ( kinda looks like a [ bolted to the bottom of the bracket and to the engine compartment) and the part of the tank that has the hole and arm is on the bracket that held my stock air box in, that the sc cars dont utilize stock
the coolant hose is now routed under, so its gravity feed, that picture was right after i installed it
Old Jan 9, 2011 | 08:44 PM
ssyellow's Avatar
Thanks for the response. Any idea where I could possibly find that piece?
Old Jan 9, 2011 | 08:55 PM
glen229's Avatar
Its 1" wide aluminum bar I cut and bent in a vise
Old Jan 9, 2011 | 09:10 PM
ssyellow's Avatar
Alright. I'm thinking I will just buy various aluminum bars, plates and such to see what I can come with haha.
Old Jan 9, 2011 | 09:13 PM
glen229's Avatar
Now ur thinking
Old Jan 9, 2011 | 09:33 PM
Bluelightning's Avatar
Got Bewst?
I did the same. Just took a thin sheet of aluminum, cut it, bent it in the vise, drilled my holes and painted em
Old Jan 9, 2011 | 09:57 PM
T CUPP's Avatar
where would you buy the stock tank or whatever from?
Old Jan 9, 2011 | 10:24 PM
ssyellow's Avatar
Looks like that's the way to go then. Thanks for the help guys, appreciate it.
Got mine from someone on here. You could also: Buy OTTPs Option B kit, get part number and buy from stealership, find any wrecked cobalt in a junkyard and get it there.
Old Jan 9, 2011 | 10:31 PM
05Slowline's Avatar
i just used some random metal scraps i found when i was like ehhh zip ties looks ghetto, lmao
Old Jan 10, 2011 | 07:18 AM
Staged07SS's Avatar
Administrator
Administrator
I use ZZP's bracket for my Option B tank.
Old Jan 10, 2011 | 10:31 PM
ssyellow's Avatar
Meh it's kinda pricy and I'm cheap, to a degree hah. Does look nice though.
Old Jan 11, 2011 | 09:52 PM
ssyellow's Avatar
Quick question, where could I buy the restrictor that goes in the air bleed line?
Old Jan 12, 2011 | 03:20 AM
goeckeritz123's Avatar
Create engine depot
Old Jan 12, 2011 | 07:13 AM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by goeckeritz123
Create engine depot
This.
Old Jan 12, 2011 | 09:05 AM
87gn06gto07irl's Avatar
Napa. Beats waiting and paying shipping. Or make one. The hole is .040
Old Jan 12, 2011 | 05:08 PM
ssyellow's Avatar
I'll look at Nspa first, then crate engine. Is it .040 of an inch? Also, would modifying the tank to be flow through be more beneficial than just having the tank there for added coolant?
Old Jan 12, 2011 | 05:59 PM
05Slowline's Avatar
This, don't know why you'd buy from CED just that piece alone, it'll cost 10 bucks by the time you're done. Napa sells a whole + of different sizes just go in and look for barb restrictor or ask someone there they won't try to look it up on the computer like autozone
Not really, unless you plan on having a monkey in the bay to throw ice in it every minute
Old Jan 12, 2011 | 06:03 PM
07BoostedG5's Avatar
Made my own
Old Jan 12, 2011 | 08:10 PM
ssyellow's Avatar
Good point hah. Not too many Napas around but I'm an Autozone guy so I will be going there first.
Originally Posted by 07BoostedG5
Made my own
Looks nice, I will be doing some mock ups when the tank gets here. Thanks for the pics!
Old Jan 22, 2011 | 04:32 PM
ssyellow's Avatar
Could someone post up a link or picture of what exactly the barb restrictor is? Having trouble finding it. Also, where does it go in relation to the plumbing? Closer to the tank or near the bleed hole on the stock heat exchanger?
Old Jan 22, 2011 | 06:48 PM
You really dont need it^
Old Jan 23, 2011 | 11:27 AM
ssyellow's Avatar
Just going to make my own now, simple and fast. I got a sheet of aluminum but I was wondering what your process was in making your brackets. Do I cut the little notch out for where the tank mounts and then bend it? Also in that picture the mount on the left side closer to the tank, what does that piece look like?
Old Jan 23, 2011 | 02:14 PM
qwikredline's Avatar
Fail. You do.
