difference between ca v1 and v2 header
Does anyone know what the difference/s is between the ca v1 and v2 header. Are the specs the same? I know people like the v2 header but was the v1 header a good header?
Well i heard the v2 rubbed a coolant line but all you had to do was loosen two bolts on that line and you could move it out of the way. The most important thing to me is that the header will be reliable with no leaks. Can someone with the v1 header chime in?
Oh and does anyone know the specs on it? Would it be a good header for my setup or would i need one with larger primaries, collector etc.
z28addiction
Sep 28, 2015 12:03 AM
