disconnect the battery
Old Feb 29, 2008 | 10:08 PM
srowler9's Avatar
guys, I'm installing the injen cai intake tomorrow on the 2.0, and I want to know 2 things.
1) Do I need to disconnect the battery before the install?
2) Is there anything that will help out the install, or anything that I need to know?
I can't find these to questions in the search button.
thanks guys!!!
Old Feb 29, 2008 | 10:11 PM
eastcoastz's Avatar
Yes disconnect it for the entire install.
As far as help goes, put tape around the hole the intake goes through so you don't scratch up the intake.
Old Feb 29, 2008 | 10:14 PM
srowler9's Avatar
any reason for the battery disconnect?
Old Feb 29, 2008 | 10:20 PM
Nyke's Avatar
Memory re-learn
Old Feb 29, 2008 | 10:25 PM
eastcoastz's Avatar
You got it!
Old Feb 29, 2008 | 10:29 PM
srowler9's Avatar
anything else i need to know
Old Feb 29, 2008 | 10:31 PM
Beck's Avatar
disconnecting the battery resets the fuel trims, basically by resetting them you force your car to relearn the new trims with the increased airflow of the intake.
eastcoastz's Avatar
Just make sure it positioned PERFECTLY because mine was not and it rubbed holes in 2 different places.
Old Apr 11, 2008 | 01:36 PM
1BadBlueSS's Avatar
Do you totally disconnect the battery or just the negative?
WhineSSbaby
Sep 1, 2020 12:39 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Meadowvalien
Aug 17, 2017 06:32 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
