Which do you prefer as an upgrade?
Yeah, I get that. I just think we max our MAP sensor out around that 22 psi number. So I don't know if you could run much smaller without a MAP clamp or something. It would still be damn good. I would LOVE to get rid of that much heat.
Originally Posted by Cobalt_Supercharged
The downside is it's always under load. Even with the bypass.
The other thing is the last time I spoke to Whipple they said the W75AX won't be ready til the end of the year.
Originally Posted by Pyros777
Well if an M90 w/ bypass valve can put out comparable numbers to the whipple, then I'd change my vote to the M90.
The whipple is going to cost more than the M90, period. The 140AX is the only whipple option I can use, which is going to put out far more power than I probably want (In excess of 400hp) since the blower is .3 liters bigger than the engine. This also means I would have to port the head, special exhaust, and probably new pistons and rods just to handle the load of the boost. It's starting to sound all too much like a Honda build-up, let's not forget stronger axles and clutch just to hang with this thing. I'm siding more with the M90 blower, ported, and double aftercooled just like I thought before. This would cost ME less than 2 grand, and certainly put out enough power to make way for a mid 12 second pass, IF I could hook up enough. Until I have an upgraded clutch and axles, I could only boost to 12psi on the M90, until I upgraded the clutch and axles, still making another 50hp or better, which is enough to hang w/ LS1's and GT's of the sort. Might I add the M90 isn't even in it's efficiency range at 12psi boost...only at about 17psi will it reach a good efficiency, which means that blower could probably make more power than needed to make a car fast. Personally, if I reach 350whp, I'm going to stop there. Because it's a street car, and I'd rather do a weight reduction, maybe 150-200lbs, and gain about .3 seconds on the quarter mile, instead of adding 50hp to do the same. Reliability is paramount folks. Besides that, a 350+whp 2700lb Balt could probably pull on a Viper in a roll-on. Fast enough for me. If I could do all this for a reasonable amount, say $3500 bucks, clutch, axles, injectors, fabbed blower, aftercooler, and HpTuners with a tune on a dyno? Of course I'm going this route. If you think otherwise, please give a detailed reason why I should do it YOUR way. I need specific facts and numbers to back up your opinion.
In regards to Cobalt Supercharged....the higher the output of the motor..(Meaning the higher performance)...the greater the peak will be of the RPM. For instance...I have a 97' Z71 4WD truck. It makes about 255hp and 300ft/tq. Well, it's all peaked at about 2500rpms. Take that same 5.7L motor (350ci) and let Corvette modify it. The car now makes 350hp, 350ft/tq but peaks at about 4000RPM's, maybe 4500. Same motor w/ higher performance = less low end power. That's a known fact about engines. The peak power will shift the higher you go up in cumulative HP and TQ. Same thing with turbos. Make more total power, just later in the RPM. And we all know that doesn't matter so much when racing.
I meant that the S/C isn't efficient when spun at lower rpms as in a larger pulley not the engine rpm. I understand that twe really don't need the lower rpms for race cars since most of the time is spent in the higher rpms.
It really doesn't matter how large of an Eaton blower you use, they are not designed to be efficient at high levels of boost. Shoveing more air(CFM) in the same amount of space is always going to create higher pressure. 12 psi with an M62 will produce the same power as an M90. (Actually the M62 would probably result in more power to the crank because of the greater parasitic drag of the M90)
Right. 12 psi on our car with an M90 would be out of the efficieny range of the blower. What I was say is that people tend to think that 12psi with an M90 is better than 12psi with an M62 because the M90 supplies more CFM. You are right about the M90 being more efficient at higher levels of boost, but it is still not as efficient as a W75AX at the same level of boost.
Yeah I'm very skeptical of the Twincharge set up. Like you said, you are using the 2 hottest methods of FI to create high levels of boost.
I'll stick to my twin screw. 22 psi with half the temp and almost the same amount of power required to turn as the stock blower at 12 psi.
Come on you pussies you need this turbo
http://videos.streetfire.net/video/2...af4dd0584e.htm
you have to go Whipple/twin screw.
The eff% is SO much higher and it acts much like our stock blower in respect to low end power and heat creation.
BUT its SO much better at the higher boost levels most of us are runing.
