does this sound right?
mods:
KnN intake
pacesetter header(1.75"primaries)
catless LSP dp
2.5" catback exhaust, megan racing resonator, obx muffler, magnaflow tip
3" pulley
sgII injectors
im gettign 12psi, 13max...im not sure if thats right as i though the 3" would give it a good 14-15psi?
KnN intake
catless LSP dp
3" pulley
sgII injectors
Sounds dead on
On my ZZP 3" pulley I boost 14.1 @ 7000rpm @ 50' elevation
A lsj w/ just GM stg2 on it usually boost roughly 15.5 PSI
Mods to contribute to my set boost level
LS4 tb
Ported Intake Manifold (.4 drop in psi)
Custom 3" DP w/ high flow cat (1 psi drop)
STOCK LSJ EXHAUST MANIFOLD / 3" resonator / 2.5 piping to a stock LSJ MUFFLER
The header you have in combo w/ a catless DP easily drops 2.0-3 PSI
LS4 tb
the header and dp would have nothing to do with a drop of pressure from the sc. they are a completely differnt system.
It's completely useless to open up the exhaust piping after the exhaust ports on the head.
BECAUSE..... It does absolutely nothing.
Please read the post below
Hmmm, I'll answer this simply.
If our motors (or any motors in general) are one giant vacuum pump. Whats to happen if you improve upon a restriction?
Better airflow and less restriction. Hence dropping boost.
As the exhaust side of the vehicle is no longer working hard to extract exhaust gases, making it much easier for boost to pass thru the motor, causing less pressure build up in the cylinders.
To the OP, your boost seems fine.
Think of it this way
Boost is Cyl. pressure
remove the cyl pressure
and there you have it, less boost
As for the 2-3 psi drop
Your typical midlength or shorty header w/ 1.75" primaries to a 3" collector usually drop on avg. at least 2 psi
A catless dp; and this is including the stock lsj dp w/ it's wonderful crimp. I've also personally seen it drop a full PSI
a catback makes a minor difference; but if your looking for even more flow. a 3" to a straight thru muffler would possibly drop .5-1 psi
yes i understand that but what im saying is. the stock pulley and tune reaches 12-13 pounds of boost. there is no reason why he would be losing that much boost to where he is running basically stock boost numbers.
Jn2 is a 2.2 cobalt. His head flows differently than ours and their boost readings are gonna be different on the pulleys.
Jn2, you need to post in the 2.2 section, not the 2.0 section.
HUNTERKILLER boosted roughly 12 psi on similar bolt ons w/ his 2.2 S/C with the 3" pulley.
But def. posting in the 2.2 section would of cleared this up ages ago.
2.2 section doesnt have many people that would help, all those who can post in here aswell, and stock i was seeing 10psi which is what the lsj gets isnt it? i understand that having a better flowing exhaust will drop boost, was just asking if it would be the cause of a 2psi drop...im ok with loosing psi as long as it still makes more power...and the boost gauges reads boost @the manifold, so if the engine is taking in more air, than theres less left in the manifold to be read, which like i said, im just seeing if that # looked aboutright
DANRICKARD
Oct 1, 2015 12:08 AM
