Does this timing appear to be set correctly?
From: Voted by the people, most likely to get pulled over by a cop
Having an issue with my build. Car wants to turn over, cranks but doesnt fire. Spark test was good and we are getting fuel. Im checking my timing and this is how it's set now. Before I button her back up, any suggestions on what else to look at or try? The cam position sensor was aligned with the hashmark as well intially.
thanks in advance
thanks in advance
thanks in advance
thanks in advance
yeah, I did giggle at the 2 turns thing. I'll guarantee Witt is correct haha
Ive spun it over many a time previously to ensure everything is ok.
Any other suggestions of what could be wrong? I'll take a vid when i turn it over tomorrow. I'll put her back together after work and give it another whirl.
not sure exactly what you are asking. The crank pulley is on correctly if thats what ur asking?
? for the group
Does #4 need to be TDC when setting the cam position sensor?
? for the group
It's just that in the picture you have of the crank sprocket the colored chain link looks correct but I can't see the crank key at the 1 O'Clock position. Is your crank key at the 1 O'Clock position at the same time the colored chain link is on the mark (like pictured - 5 O'Clock position) when both cam sprocket's colored links are on their marks?
Like this:
good luck with this I have done this once and it is a bitch #1 should be top dead center and the camsshould be a 10 and 2 which they look right and same with the crank, dumb ? but it happened to me did you plug the cam position sensor back in?
Like this:
Like this:
When i did it i never used this key, its the first time i have heard of it, i just used the timing mark. With the lighting and angle of the picture its hard to see if the mark is at the link
Number 4 needs to be at top dead center compression, not exhaust, when lining up and inserting the cam sensor. If you think that may be contributing to your problem, simply unplug it until you find the problem, it will start without it (it should start with it installed incorrectly but I've never tried it when its 180 degrees out of phase).
lol, your welcome. You still have my number? Call if/when you put yours back together
Isnt that square key also what lines up to mount the crank pulley?
The red link is lined up with the white dot on the crank.
The drawing I provided in the previous posts is straight out of the GM Cobalt factory service manual.
but to the op yes your on the money, now one thing i wasent sure of is the balance shafts in relation to crank position which is why i spent 20 min turning it over by hand and lined up the accy drive chain and its marks first then the timing chain and its marks and my car fired first time and ran great... lots of people run into probs here....
Last edited by hungryhip-ccp; Dec 5, 2008 at 11:19 AM. Reason: Automerged Doublepost
roth
Sep 26, 2015 12:16 PM
