Does this timing appear to be set correctly?
Old Dec 2, 2008 | 07:15 PM
mrphoto103's Avatar
From: Voted by the people, most likely to get pulled over by a cop
Having an issue with my build. Car wants to turn over, cranks but doesnt fire. Spark test was good and we are getting fuel. Im checking my timing and this is how it's set now. Before I button her back up, any suggestions on what else to look at or try? The cam position sensor was aligned with the hashmark as well intially.
thanks in advance
Old Dec 2, 2008 | 07:16 PM
FZWCobalt_09's Avatar
That looks right to me...
Old Dec 2, 2008 | 08:18 PM
mrphoto103's Avatar
in case it doesnt turn again any suggestions on what else to check anyone?
Old Dec 2, 2008 | 11:43 PM
SuperSport4's Avatar
what ur suppose to do is spin the crank pulley 2 revolutions and if timing is set right all the marks would line up perfectly again. but ya that looks like its on the money
Old Dec 2, 2008 | 11:49 PM
Witt's Avatar
No, they wont.
Old Dec 2, 2008 | 11:52 PM
bryce712's Avatar
just finished this class in school. everything looks correct from what youve shown. is there a clearance issue with anything possibly ?
Old Dec 2, 2008 | 11:53 PM
exiged's Avatar
Originally Posted by Witt
No, they wont.
care to explain? i thought it was that way too
Old Dec 2, 2008 | 11:55 PM
Witt's Avatar
The crank sprocket has about 20 teeth, the chain has a bit more than that.
You spin the crank twice to ensure you have no clearance issues. If you keep going until the marks line up again youll be there for a very long time.
Old Dec 3, 2008 | 12:08 AM
Red07SSNA's Avatar
That is correct! It takes like 33 turns before the marks line up again!
thanks in advance
I can't see the timing mark on the crank sprocket...the crank key should be at approximately the 1 O'Clock position with the colored link in that location. Is your crank key at the colored link position? If it is, it is not timed correctly. The timing mark on the crank sprocket should look similar to the timing marks on the chain sprockets
Old Dec 3, 2008 | 12:23 AM
mrphoto103's Avatar
yeah, I did giggle at the 2 turns thing. I'll guarantee Witt is correct haha
Ive spun it over many a time previously to ensure everything is ok.
Any other suggestions of what could be wrong? I'll take a vid when i turn it over tomorrow. I'll put her back together after work and give it another whirl.
Old Dec 3, 2008 | 12:26 AM
Red07SSNA's Avatar
Did you look at your crank key position?
Old Dec 4, 2008 | 10:58 PM
mrphoto103's Avatar
not sure exactly what you are asking. The crank pulley is on correctly if thats what ur asking?
? for the group
Does #4 need to be TDC when setting the cam position sensor?
Old Dec 4, 2008 | 11:16 PM
Red07SSNA's Avatar
It's just that in the picture you have of the crank sprocket the colored chain link looks correct but I can't see the crank key at the 1 O'Clock position. Is your crank key at the 1 O'Clock position at the same time the colored chain link is on the mark (like pictured - 5 O'Clock position) when both cam sprocket's colored links are on their marks?
Like this:
Old Dec 4, 2008 | 11:54 PM
rollingboostedss's Avatar
good luck with this I have done this once and it is a bitch #1 should be top dead center and the camsshould be a 10 and 2 which they look right and same with the crank, dumb ? but it happened to me did you plug the cam position sensor back in?
Old Dec 5, 2008 | 12:07 AM
JMAc88's Avatar
Like this:
What he means by key is a square chunk missing, there is a timing mark on the crank sprocket that will line up with the colored link if this chunk is at the 1 o'clock position.
When i did it i never used this key, its the first time i have heard of it, i just used the timing mark. With the lighting and angle of the picture its hard to see if the mark is at the link
Old Dec 5, 2008 | 12:12 AM
Witt's Avatar
Number 4 needs to be at top dead center compression, not exhaust, when lining up and inserting the cam sensor. If you think that may be contributing to your problem, simply unplug it until you find the problem, it will start without it (it should start with it installed incorrectly but I've never tried it when its 180 degrees out of phase).
Old Dec 5, 2008 | 01:11 AM
spike's Avatar
saved
Old Dec 5, 2008 | 09:00 AM
mrphoto103's Avatar
Yeah, the cam position sensor is back. =)
Originally Posted by spike
saved
lol, your welcome. You still have my number? Call if/when you put yours back together
Isnt that square key also what lines up to mount the crank pulley?
The red link is lined up with the white dot on the crank.
Old Dec 5, 2008 | 11:12 AM
Red07SSNA's Avatar
Yes, the square crank key is used to line up the pulley. Your picture almost gives me the impression that the white dot is also lined up with the key -- in your picture it is not clear where the crank key is -- it looks like there is a black square inside the white dot -- is that the crank key? If so, then the timing is not correct.
The drawing I provided in the previous posts is straight out of the GM Cobalt factory service manual.
Old Dec 5, 2008 | 11:19 AM
hungryhip-ccp's Avatar
umm like 20 min and 40 rev's lol trust me........ i know..... haha
but to the op yes your on the money, now one thing i wasent sure of is the balance shafts in relation to crank position which is why i spent 20 min turning it over by hand and lined up the accy drive chain and its marks first then the timing chain and its marks and my car fired first time and ran great... lots of people run into probs here....
Last edited by hungryhip-ccp; Dec 5, 2008 at 11:19 AM. Reason: Automerged Doublepost
Old Dec 9, 2008 | 11:50 PM
mrphoto103's Avatar
i used neutral balanced shafts
Old Dec 12, 2008 | 01:21 PM
shutzero's Avatar
click
bigdeertz
Nov 17, 2016 09:41 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
roth
Sep 26, 2015 12:16 PM
