Drive train "slack"
Old May 18, 2008 | 06:27 PM
Geardog3's Avatar
Drive train "slack"
My '07 SS/SC seems to have a pronounced amount of slack in the drivetrain. It's most prevalent at low rpm in first and second gears when going from accelleration to decelleration. When you're in first and your jack the throttle on and off it just seems like the engine is flipping back and forth in the engine bay. Is this common? I was wondering if the Ingalls damper might help or maybe I have a bad mount. There is a bit of wheel hop when you jump on it. Any thoughts? Thanks.
Old May 18, 2008 | 06:28 PM
chris88z24's Avatar
The damper helps a little bit the engine still moves. If you don't mind the vibes i'd go with solid mounts and prothane tranny bushings.
steddy2112's Avatar
Get some mounts and call it a day.
bigrroberto's Avatar
yes get the dampner and then swap out your mounts
Old May 18, 2008 | 06:33 PM
Mr_Slobalt's Avatar
mounts
Old May 18, 2008 | 06:35 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Don't buy the Damper... just jump straight to the Poly Trans Mounts. You can buy them from ZZP and have them very soon (they usually ship my stuff the day after I order). I bought the Damper and then the mounts... and then I sold the damper, because it was useless with the mounts.
https://www.zzperformance.com/cobalt...=546&catid=146
As far as the slack, I know what you are talking about. The mounts (of any kind) don't seem to help that. And I don't know what does.
Old May 18, 2008 | 06:39 PM
HackAbuse's Avatar
Check your control arm bushings.
Mine are shot at 45,000m and my entire wheel assemblies can move forward and backward a good two inches or so between braking and accelerating
Old May 18, 2008 | 06:43 PM
RooTBeeR's Avatar
Yeah man, I got my '07 back in September...I know/ hate exactally what you are talking about. I just ordered the TTR tans mounts a Friday night. lol
Old May 18, 2008 | 10:04 PM
INFE's Avatar
yea i have the same problem. Im going to be ordering mounts soon.
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
ernnyyes
Oct 2, 2015 05:16 PM
importkiller
Sep 30, 2015 07:18 PM
jmelton327
Sep 26, 2015 10:04 PM
