Dry Sump....
Old Mar 28, 2007 | 09:28 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
Dry Sump....
I have chosen to add a dry sump to my project. To minimize the time needed to produce this for my car I am wondering if anyone knows of a company that has already made a dry sump kit for the LSJ?
I have found that ARE makes something for the Ecotec and it looks like they used a dry sump on the Time Attack Cobalt but the more options I have should speed the process up.
Thanks in advance.
Old Mar 28, 2007 | 09:44 PM
Johnboy12358's Avatar
Ok, noob warning....
Dry Sump?
Old Mar 28, 2007 | 09:45 PM
CTORANGESC's Avatar
Its an external oiling system.
Old Mar 28, 2007 | 10:47 PM
ahh ok, thanks
Old Mar 28, 2007 | 10:49 PM
Tomtwtwtw's Avatar
Helps prevent the engine from being starved of oil during extreme lateral g's...
Old Mar 28, 2007 | 11:05 PM
ahh i see
Old Mar 29, 2007 | 12:15 AM
c24na's Avatar
Also keeps oil from splashing on the crank and slowing the rotation, which = more free up hp.
nate
Old Mar 29, 2007 | 12:20 AM
ItalianJoe1's Avatar
Question for you-
Are you gonna use an engine driven system, like the new Z06, or a standalone Accu-sump style one?? My dad used to build a race car for SCCA racing, and it had a separate dry sump with its own pump. Nothing like flipping a switch and having like 80psi before even cranking the engine.
Old Mar 29, 2007 | 12:44 AM
ImaginaryForce's Avatar
Sweetness + More Horsepower = Dry Sump
Old Mar 29, 2007 | 01:12 AM
nate
Yes
And Yes
Originally Posted by ItalianJoe1
Question for you-
I believe the plan is to use a pulley driven pump that is run off the accessories not the engine. The decision was just made today so we will have a concrete answer sometime next week.
Old Mar 29, 2007 | 01:15 AM
ReggaeRampage's Avatar
Dry Sump?
I was thinking the same thing.
Old Mar 29, 2007 | 01:17 AM
Originally Posted by victory_red_SS
Yes
And Yes
Ok, i was just wondering. I know a lot of new performance cars with dry-sumps are using a pump set up like a power-steering pump, belt driven off of the crank, so it works like a normal pump with only some of the advantages mentioned above, also with remote resivors and oil coolers. The original dry-sump systems were also designed for less wear, by allowing you to start the engine with oil pressure, and to remote mount the pump and resivior, like in the trunk or something, for weight, temperature and space reasons. Kepp us informed.
Old Mar 29, 2007 | 02:35 AM
Tung's Avatar
hey rod is your car going to be at DTP this june?
Old Mar 29, 2007 | 08:42 AM
No
The dry sump is going to add some time to the project so I am thinking I should have it back say 2009. Actually I am setting an unmovable completion date of Aug 15th, 2007.
Old Mar 29, 2007 | 06:53 PM
Well I lucked out, finally. I talked to ARE and they have a complete dry sump kit that "is" the same type as those uedd on the Corvette. The only thing required will be the lines.
The downside is that it's pulley is mounted where the A\C is. We are going to investigate an alternative way to have air conditioning but I may end up sacrificing it, which I really don't want to do.
Old Mar 29, 2007 | 07:17 PM
g5mike's Avatar
Oh ok! this is nothing like dry socket.
Old Mar 29, 2007 | 07:21 PM
SuperEco06's Avatar
Now after reading this I have been researching dry sump setups. Is Accusump a true dry sump system? If not is it as good as, or is it kinda in between wet and dry sump?
Old Apr 4, 2007 | 02:27 AM
EmperorJJ1's Avatar
sry for the thread jack but do you have a thread about your RWD conversion... im hoping theres a kit
Old Apr 4, 2007 | 02:33 AM
TurboTechRacing's Avatar
Thanks in advance.
I did this back in the day on my Cavalier with the 2.4L LD9 engine, i used the complete Moroso setup, stage 3 pump, 1.5 gal oil tank, etc. Worked very well, I did have to make a custom bracket to mount the pump where the A/C pump went, and then i took the crank pull and added a hub to it, that mounted the drive gear pulley on it. Cost about $2000-$3000 to do, but in an all out drag car it is a must. Car rev faster, made more power, more constant oil pressure.
If you have any questions we can help you out, just let us know.
Old Apr 4, 2007 | 09:17 AM
The expense of doing this will likely change your mind on RWD, but if not I am sure the companies doing this would provide the information on what all was done. As for a kit, I don't see enough demand to make one of those.
I will keep that in mind. The downside with the ARE kit made for the Time Attack Cobalt is GM didn't want A/C and thats where the pulley was postioned. Because I plan on driving on the street still, I really want A/C.
Old Apr 4, 2007 | 09:32 AM
06blackg85ss's Avatar
yeah I was gonna tell you that, but saw the thread too late.. lol I was researching it for my car, and since I don't have a/c anymore..... it shouldn't be an issue. But now just gotta get some cash together and finish the motor, than I"ll think about going drysump. but from what I researched ARE has the best setup out for the ecotecs.
Old Apr 4, 2007 | 09:44 AM
When I talked to ARE the fellow said GM sent them not one but 2 LSJ's to design the dry sump kit. The engines are still sitting there. Must be nice.
As for the A/C we are looking at making a setup similar to the design of the supercooler being designed for my engine. Hopefully we get to have some type of A/C as there was also an issue of the T56 transmission sitting where part of the A/C unit normally is.
bigdeertz
Nov 17, 2016 09:41 AM
brandon04
Oct 21, 2015 07:04 AM
How to Guide
57
Oct 15, 2015 11:56 AM
RyGuy
Sep 21, 2015 10:03 PM
yellowsupercharged06
Sep 17, 2015 04:40 PM
