dual bypass + ca heat exchanger
Old May 17, 2007 | 06:14 PM
sp123's Avatar
Ok i need some help. I just bought the dual bypass set up from gm and i have a ca heat exchanger on order. I chose to run option b for the dual bypass. When i go to install the extra cooling tank where will the bleader hose go. The cA heat exhanger does not have a port like the stock aftrecooler does.
Old May 17, 2007 | 06:19 PM
R&C_rallySS's Avatar
I'm not sure, I live in Lebanon so I would love to meet up with some reading guys. As long as I don't get shot lol. j/k. I wish I could help you but I have yet to install dual pass or a CA H/E. Good luck man.
Old May 17, 2007 | 08:28 PM
sp123's Avatar
nobody knows
Old May 17, 2007 | 09:20 PM
BCobaltSS's Avatar
the 1/4'' hose route from the top of the extra tank to the front of the passenger side underneathe the grill . You have to pop the snap clips that hold the grill in and pull it back enough to see the top of the radiator and you will see a plug . That is where the 1/4" hose goes.
Old May 17, 2007 | 10:58 PM
sp123's Avatar
no i am talking about using the cobalt addiction heat exchanger not the factory one.
please you heat exchanger guys need help
Old May 17, 2007 | 11:21 PM
Shanman's Avatar
y not run both and do the Heat Exchanger Modification Protecter or H.E.M.P. for short if not u might be going up in smoke. HEMP is great on those long trips where animals can jump out and **** ur **** up
Old May 18, 2007 | 02:34 AM
Blown 4-banger's Avatar
Please tell me you did not take out the stock HE when you did the CA one. If you did, right now, take your right hand, and slap yourself in the face as hard as you can, then go outside and put the stock HE back inline with the CA one
Old May 18, 2007 | 07:12 AM
sp123's Avatar
i dont have my cobalt addiction heat exchanger yet. I said that in the first post. They tell you to take out your stock heat exchanget though
Old May 18, 2007 | 07:22 AM
ItalianJoe1's Avatar
There is not a bleeder port on the C/A H/E. If you wanna run the option B setup you need to keep the stock H/E as well. I plan on doing this when I install the H/E sometime next week. Just gotta get my brackets ready. Don't wanna jus use thiers, they will get rusty. I'm debating painting them in black wrinke paint or making them outta stainless or aluminium.
Old May 18, 2007 | 07:28 AM
sp123's Avatar
is it good to keep the stock heat exchanger with the ca one. Will my radiator get enough air. Also can i turn the ca one upside down and use the drain as a bleeder. Also will the ca one make that much of a difference compaired to stock
Old May 18, 2007 | 07:41 AM
SS33's Avatar
^Yeah it is good to keep the stock HE and just add the second HE inline. But, I would not recommend turning the CA unit upside down to try and use the drain as a bleeder. Just use the stock bleeder for your option B and you will be all smiles.
As soon as my dual pass is finished and my surge tank comes in this is how mine will be set-up.
Also the stock HE is sandwiched between the AC condensor and the Radiator, it would be a nightmare to remove
Old May 18, 2007 | 07:21 PM
sp123's Avatar
ok so i am being told to keep my stock heat exchanger is the cobalt addiction heat echanger worth waiting for
Old May 18, 2007 | 10:12 PM
Plumb the CA heat exchanger in AFTER the fluid passes through the stock HE. I can't imagine what CA was thinking when they said to remove the stock HE.
Old May 18, 2007 | 11:35 PM
sp123's Avatar
so def run option b with keeping the stock heat exchanger
Old May 19, 2007 | 08:35 AM
Maxim_X's Avatar
Everyone who is doing this is running dual heat exchangers...Like me!!
Old May 20, 2007 | 12:56 PM
SS33's Avatar
I don't know about the CA unit, but so long as it doesn't leak it will do the job man. Pretty much any HE (of adequate size) is going to be beneificial in this set-up.
I know it can be done ALOT cheaper than what they are charging. My set-up, with the Cobra HE and bwoody brackets will be up and running for ~130. I'm just waiting on CED to ship my dual pass, surge tank, and a few other pieces, then hopefully I'll be up and running cool next weekend
Old May 26, 2007 | 05:50 PM
just1's Avatar
I plan on installing the dual pass Option B....and now I'm kicking myself in the ass for taking the stock heat exchanger out. I figured I didn't need it because I replaced it with the CA heat exchanger. The GM dual pass kit didn't exist back then.
BTW....my original ac condensor, stock heat echanger, and radiator was damaged from running over an un-avoidable tire on the road at 85MPH.
Now need to search for a stock heat exchanger.
turbochargedss2012
Sep 20, 2023 12:17 PM
DarrenGC
Dec 24, 2021 01:55 PM
n20saturn
Sep 30, 2015 12:26 AM
Sep 27, 2015 08:53 PM
jmelton327
Sep 26, 2015 10:04 PM
