dyno on 42's
Old Oct 18, 2007 | 01:49 AM
  #51
Psykostevo's Avatar
Originally Posted by damien
Area uses his stock windsheild washer resiovor. Correct me if i'm wrong, isn't there a dummy light in our cars that say when the fluid is low?
No, there is not. I have experience with 2 Meth cars, and they run out when they run out. No waning. Bad for the pump too, but worse for the motor.
Old Oct 18, 2007 | 01:53 AM
  #52
Blown 4-banger's Avatar
Originally Posted by lsjwannabe
as long as you don't beat on the car to bad you don't have to worry about the afr to much i ran 12.5 for the longest time on my 2.5 pullied setup without one hicup. The reason why your car blew was becuase of the heat from all the back to back to back runs and how you drove your car
Yeah, I know. If the car can't hold up to the way I drive, then it needs to be fixed
Old Oct 18, 2007 | 05:03 AM
  #53
Doc's Avatar
Doc
Originally Posted by ebristol
Ok I might have to throw out a BS here. Here is a conversation I had with Area47 on 10/11 on RLF. He seemed pretty adamant about not putting 42’s in his car.
No wonder he won’t offer anyone the tune….
We were talking about the tb out of Trailblazer, Envoy, etc.
What are you calling bs on..?? He mentioned his 42's were going bad weeks ago.
I've been running ~12.3 since I've been able to tune, right after hptuners came out, and I have only had issue since I got to SoCal. I've made it a tad richer since this gas sucks.
Old Oct 18, 2007 | 10:20 AM
  #54
Area47's Avatar
Rent me! per hour
egt hit 1375 with an afr of 12.3. iat2 of a peak temp of 122 degree's. that run was done on the failing 42's they are done.
jmc, i won't go any leaner due to the whole 91 octane pump gas deal. that was done on pump gas, and water injection.
cam. do you know what your egt's where when you popped it?
as far as the windshield resivoir, there is a dummy light for the low level, but one must keep in mind, the shur flo pump moves a lot more fluid than the stock pump would ever dream of. by the time you run out. it's done. i just keep an eye on the fluid level.
also, having a built short block is not going to save your motor from you being stupid.
Old Oct 18, 2007 | 10:52 AM
  #55
ebristol's Avatar
I was calling bs on the fact that the dyno run was on 42s. Those numbers would suggest a very solid run on 60s. And by the short conversation I had with him 6 days ago it seemed like 42s were way in the back of his mind. But idk.
I thought he was just messing with us!
Old Oct 18, 2007 | 11:06 AM
  #56
Area47's Avatar
Rent me! per hour
nope! not messing with you. that was 42's. i pulled them that weekend
Old Oct 18, 2007 | 11:17 AM
  #57
lsjwannabe's Avatar
yeah i will back area up the guy knows what he is doing with tuning and has helped me quite a few times
Old Oct 18, 2007 | 11:48 AM
  #58
ebristol's Avatar
Dam you are really at it! Keep up the good work.
Old Oct 18, 2007 | 11:55 AM
  #59
Blurred Vision's Avatar
Isn't there a tune in the HP Tuners repository files for a 2.8 with 42's????
Old Oct 18, 2007 | 12:18 PM
  #60
refosterIV's Avatar
Wow that is wicked! When I get my stage 2 your going to help me out right? No really sweet setup
Old Oct 18, 2007 | 12:39 PM
  #61
Darksun's Avatar
no catch. just a lot of work
on that run
2.8
42's {tired 42's}
pace setter ceramic coated header
3 inch dp
3 inch cat back
k&n
water/alky mix in the resivior {water injection}
Im going to the dyno with paul this sunday. i'll show you what stocks injectors and 13.5 a/fs can do.
COBALT POWA!!!!!!!
Old Oct 18, 2007 | 12:45 PM
  #62
lsjwannabe's Avatar
blow the motor eventually but make some sweet numbers in the process
Old Oct 18, 2007 | 12:47 PM
  #63
Burn a piston
Old Oct 18, 2007 | 12:48 PM
  #64
lsjwannabe's Avatar
a third gear run he might last 4th gera it might go down the drain
Old Oct 18, 2007 | 12:55 PM
  #65
Area47's Avatar
Rent me! per hour
COBALT POWA!!!!!!!
your car scares me anyways!
Old Oct 18, 2007 | 01:07 PM
  #66
Darksun's Avatar
Nah that woulda happened along time ago. Paul Finally gave me back my tune he took away from me so i could take out this srt-4 that ran 13.3 at 105 at the track. Mission accomplished but now my clutch is slipping over 6800 rpms. DAMN you paul why'd you give me back my power!!!!
I think i can tie your HP but my TQ is in the rsx-s teritory. then again im going to a differnt dyno so maybe i'll get screwed.........
Originally Posted by Blown 4-banger
Burn a piston
no ones brave enough to extract the powa that can be found running n/a A/f's
Old Oct 18, 2007 | 01:08 PM
  #67
Area47's Avatar
Rent me! per hour
lol. have fun man! my torque comes from the timing down low. i was looking at some other 2.8 dyno's so far. i have yet to see any of em that high in the torque range.
Old Oct 18, 2007 | 01:13 PM
  #68
Darksun's Avatar
I was running a timming map similar to the stage II down low and it didn't do **** for me. Then again my pulley ain't really known for bringing any TQ to the table.......
Old Oct 18, 2007 | 01:19 PM
  #69
Area47's Avatar
Rent me! per hour
i never pulled more than 227 on the torque side of it with the s2 pulley.
Old Oct 18, 2007 | 03:19 PM
  #70
Darksun's Avatar
ha your TQ > Mine
Old Oct 18, 2007 | 03:28 PM
  #71
M-Dub's Avatar
Nice buddy! And yes for those that are still questioning that run was done on 42's!!!
I think Area, myself and I don't know who else are going back down to dyno this weekend...we'll see what it is on the 60's!
Old Oct 18, 2007 | 03:33 PM
  #72
Area47's Avatar
Rent me! per hour
ha your TQ > Mine
my ability to cram a **** ton of timing down it at low rpms Vs a slow ramp.
dub. modified by kc is booked this weekend.
Old Oct 18, 2007 | 03:43 PM
  #73
RedlineBrian's Avatar
Darksun's car is uh hmmm special.
Nice job Area.
Old Oct 18, 2007 | 03:51 PM
  #74
Area47's Avatar
Rent me! per hour
Nice job Area.
thats putting it lightly
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
footballplaya3k
Sep 28, 2015 11:14 AM
Sep 27, 2015 08:53 PM
Cptnslo
Sep 24, 2015 09:32 AM
