dyno run
dyno run
Ok so i went to the dyno yeserday and yes it was in a beatup shop but he said i ran 212 hp at 190 ftlb torque i dont believe his dyno was accurate my interceptor gauge reads 263 hp and 0-60 in 5 flat seconds my mods ar stage 2 kit, vibrant performance header, 2.5" catless dp, 3"gmpp exhaaust, 3 inch pulley, ingalls torque damper , zzp stage2 H/E , a m runnin 15 lbs of boost i have race and beat an infiniti 35 an a 350z both have about 306 hp so does 212 sound right or the 263
there is no gmpp 3" exhaust
usually stg 2 + stock exhaust = 15psi...still doesnt mean much
and yeah, that sounds like its low.
post the graph if you can
higher pressure(barrometer) and colder temps = higher boost/more dense air...colder it is the less gas(air) molecules will expand meaning more oxygen able to get into the engine
your aren't going to get a correct hp reading from your interceptor.....when i was gms2 tune and 3.0 it said 300 some hp on mine lmfao.
curves look normal so yeah, probably just reading a bit low/not calibrated like exsoccer said
Things like exhaust modifications, elevation, climate, and location will affect the boost levels.
