dyno run
Old Mar 7, 2012 | 08:06 PM
Mike S's Avatar
dyno run
Ok so i went to the dyno yeserday and yes it was in a beatup shop but he said i ran 212 hp at 190 ftlb torque i dont believe his dyno was accurate my interceptor gauge reads 263 hp and 0-60 in 5 flat seconds my mods ar stage 2 kit, vibrant performance header, 2.5" catless dp, 3"gmpp exhaaust, 3 inch pulley, ingalls torque damper , zzp stage2 H/E , a m runnin 15 lbs of boost i have race and beat an infiniti 35 an a 350z both have about 306 hp so does 212 sound right or the 263
Old Mar 7, 2012 | 08:09 PM
EXsoccer1921's Avatar
if its a "beatup shop" i would imagine their dyno isn't too calibrated
Old Mar 7, 2012 | 08:20 PM
bobbyjohn681's Avatar
i dont think ur 3.0 pully is tossin 15 psi of boost, 2.9 drops about 13.5, i think 2.8 is 17 lbs, gm stage 2 kit with 2.9 pully puts down around 240whp, must have a damn good tune with the 3", but i still have my doubts on the 15 lbs
Old Mar 7, 2012 | 08:51 PM
Mike S's Avatar
it hits just over 13 and creeps its way to 15
Old Mar 7, 2012 | 08:55 PM
BankerBalt's Avatar
remember that your interceptor is also reading raw hp not whp... with a 20% loss in driveline, 210whp = 263hp.
Old Mar 7, 2012 | 09:01 PM
thats odd, idk how a bigger pulley would run more boost than 1 size smaller..anyway ure dyno pull seems low, prolly a **** dyno, should be around 230-240 depending on tune with 3.0
Old Mar 7, 2012 | 09:05 PM
BankerBalt's Avatar
depends on air density/temperature for psi
Old Mar 7, 2012 | 09:08 PM
true, never thought of that obviously lol
Old Mar 7, 2012 | 09:14 PM
Mike S's Avatar
what do you mean by density / temp psi what and how does it affect anything
Old Mar 7, 2012 | 09:15 PM
RooTBeeR's Avatar
there is no gmpp 3" exhaust
usually stg 2 + stock exhaust = 15psi...still doesnt mean much
and yeah, that sounds like its low.
post the graph if you can
higher pressure(barrometer) and colder temps = higher boost/more dense air...colder it is the less gas(air) molecules will expand meaning more oxygen able to get into the engine
Old Mar 7, 2012 | 09:16 PM
05Slowline's Avatar
too many variables to compare to people who don't live near you. i saw 14-15 fwiw on my 3.0.
your aren't going to get a correct hp reading from your interceptor.....when i was gms2 tune and 3.0 it said 300 some hp on mine lmfao.
Old Mar 7, 2012 | 09:25 PM
RooTBeeR's Avatar
on the same mods/tune i've seen from 10.3-13.8psi...so yeah boost is some what irrelevant
Old Mar 7, 2012 | 09:31 PM
05Slowline's Avatar
Your pcm auto recognized you were in cali and said fk ur boost
Old Mar 7, 2012 | 09:33 PM
rofl
Old Mar 7, 2012 | 09:36 PM
Mike S's Avatar
the chart
Old Mar 7, 2012 | 11:21 PM
RooTBeeR's Avatar
yeah pretty much...also not nearly as cold, i actually spun the 3.35" to 7354rpm and saw 14.65psi
the chart
curves look normal so yeah, probably just reading a bit low/not calibrated like exsoccer said
Old Mar 8, 2012 | 06:32 AM
Old Mar 8, 2012 | 07:49 AM
Staged07SS's Avatar
Administrator
Administrator
Front wheel drive cars do not see a 20% loss from the driveline (more like 12-15%), but yes, the interceptor reading is in BHP not WHP, and it is not very accurate.
There are too many variables to make this assumption about pulley size.
Things like exhaust modifications, elevation, climate, and location will affect the boost levels.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
dieGone
Oct 1, 2015 06:27 PM
Sep 27, 2015 08:53 PM
