e-brake trouble
e-brake trouble
Yup so day i go out to my car and the ebrake isnt working. There is no tention on the handle and i have no clue what the problem could be any ideas????? Any help would be awsome thanks.
take apart your center console and make sure the cable just didnt come undone. theres a cable that comes from the handle you pull and connects two other cables by a piece of metal that the ends clasp into. check that out first.
at the back of the e brake , under the rear cup holders if i recall right, there is a metal bracket that runs across. It splits it out from 1 line into 2 lines one that goes to each wheel, most likely one of the lines popped out, so you would need to pop it back in its hole and clamp the hole shut again.
WhineSSbaby
Sep 1, 2020 12:39 PM
XStylus
Redline Goods
17
Sep 3, 2015 10:30 AM
