E85 set ups???
Old Jul 1, 2013 | 10:29 PM
574's Avatar
574
100% meth had some 80's for sale. Fuel pump is not needed. 2005 had the weaker pump
Old Jul 1, 2013 | 10:40 PM
Dfields's Avatar
So a tune and some 80lb injectors and ill notice the difference in performance? And shouldn't be anymore dangerous to the engine?? Why wouldn't I lol
Old Jul 1, 2013 | 10:59 PM
Killa SS's Avatar
U can buy my 80#ers. Were local. Name is Rollie
Old Jul 1, 2013 | 11:06 PM
Josh171's Avatar
only thing i would recommend is change a fuel filter a few hundred miles after you've ran on E85. I plan on going back to E once i get my engine back together and broken in.
Old Jul 2, 2013 | 07:24 AM
Dfields's Avatar
Rollie are u a part of USTuners....and I'm thinking about getting ahold of zip sincewe are close to them I might buy the 80 lbs injectors from them then drive my car over their and have them tune it
Old Jul 2, 2013 | 07:30 AM
Killa SS's Avatar
Thats me.
Old Jul 2, 2013 | 10:37 AM
Hockeyman's Avatar
You can't go wrong with E85. A tune + 80lb injectors should be all you need.
The 18mpg does suck though, but that's why I have a daily.
Old Jul 2, 2013 | 03:11 PM
nhanson's Avatar
A tune is all he would need for now guys. 60s are good for this 2.9
Old Jul 2, 2013 | 06:52 PM
Dfields's Avatar
Rollie I started it...and once I go to e85 with 80lb injectors what size pulley am I capable of puttin on my supercharger and still being safe
Old Jul 2, 2013 | 08:23 PM
nhanson's Avatar
2.7
Old Jul 2, 2013 | 09:00 PM
  #36
Killa SS's Avatar
I kno. Your s/n gives it away
Old Jul 2, 2013 | 09:04 PM
  #37
JapEatr's Avatar
South Central *********
I run return style fuel system, Deatchwerks DW300 pump, injector Dynamics ID1000 injectors, and fuel pump rewire
Old Jul 2, 2013 | 09:48 PM
  #38
Dfields's Avatar
so am i right in saying my car is an 06 and from what i have been told i woulnt need a fuel pump?
Also does anyone know while running e85 what the coolant temps of the car would be as well as ait2 temps??
Old Jul 2, 2013 | 11:32 PM
  #39
Tjolley's Avatar
They dont change.
Old Jul 3, 2013 | 08:16 AM
  #40
JapEatr's Avatar
Same ect and iat2
Old Jul 3, 2013 | 02:22 PM
  #41
Area47's Avatar
Rent me! per hour
id love to see someone run 2k injectors on a stock lsj ecm.
Old Jul 3, 2013 | 02:35 PM
  #42
JapEatr's Avatar
me too
Old Jul 3, 2013 | 02:42 PM
  #43
ThexGovenor's Avatar
https://www.cobaltss.net/forums/2-0l...sticky-286997/
Old Jul 3, 2013 | 05:06 PM
  #44
Killa SS's Avatar
Why cant the stock ecm run them is there a trick to get them to work?
Old Jul 3, 2013 | 05:38 PM
  #45
JapEatr's Avatar
They will idle like your lawnmower... No low end on these tables.
Old Jul 3, 2013 | 05:43 PM
  #46
Area47's Avatar
Rent me! per hour
63 x 2.0 = the max of the ecm hard coded tables.
Old Jul 3, 2013 | 05:58 PM
  #47
Tjolley's Avatar
Standalone or a injector driver is needed
Old Jul 3, 2013 | 10:25 PM
  #48
stonny9's Avatar
Two different answers fuel pump or not... So far I'm really interested fuel injectors and a tune shouldn't be that much
Just need 80lb injectors and a tune.
I am on e47 aka 50% 93/50% e85
2.8, dual pass, flow through tank, intake, ls4 tb, header, and dp.
Only reason I went to e47 instead of e85 is I was trying to maximize my mpg to performance ratio aka I was trying to be cheap and wanted it to run slightly better in case I ever got stuck with no e85 and was desperate for gas.
deviance
Nov 24, 2015 05:51 PM
Builttss
Oct 4, 2015 10:21 AM
OrangeCoba
Oct 1, 2015 10:00 PM
Tupp
Sep 30, 2015 08:18 PM
