Ecotec vs iVTEC
My friend has a 94 or 95 civic running a GSR on 8 lbs of boost. Fast as hell, when it is running. He just blew a head gasket a while back. Before that his header got a little too hot, and the weld holding his BOV got weak and caused it to fall off. Nothing a little extra bracing and a stronger weld can't fix. Then again he does race this car hard rregularly. It is also his daily driver, even with only a roll cage, guages, racing seats and harnesses for an interior. No A/C either.
Blitz made a turbo kit for the Toyota Prius. It is limited to 6 lbs. because the the Prius engine is already running 13.0:1 compression. With exhaust and other mods, power went from 76hp and 82 ft-lb at the crank to 123.8 hp and 144.7 lb-ft at the wheels.
I know 2 contradicting stories, but that is what I have seen.
Originally Posted by zinner
http://www.comptechusa.com/store/media/dyno/RSXDyno.pdf
There is my facts
Thats the supercharger, header, intake and exhaust.
There is my facts
Originally Posted by selfinfliction
damn a supercharger that only gives 45 hp... lol is that one of those electric ebay superchargers?
and for the low price of: $4,290.00 it's a steal!!!!
especially when you compare it to a $50 pulley that can get us an extra 25
Originally Posted by DC52NV
how many horses do you think the ss/sc puts out? it's only a s/c and it's the street version.
Take a stock 2.0L LSJ with no supercharger and a stock 2.0L honda Engine K series and run them at full RPM non stop see wich one will die first... point is LSJ is a stronger Engine with more torque regardless of the supercharger.
Take a stock 2.0L Honda engine strap a comptech supercharger on it ...run it at a safe 6-7 PSI and check the compression on the engine after 20-50 000km ....trust me its not pretty I have seen it so many times......ask my Brother in his Civic hybrid turbo....4th engine this year my dad cant wait for him to get rid of those broken pistons , shadered blocks, and bend rods....
Wanna know what Honda does better then any other manufacturer ...the Engine head...they work magic on the Vtec heads.....
To each their own.
Originally Posted by ExHondaMan
In a drag race Ill put my money on the blown k20 over a stock lsj anyday. May not have the torque... but to me.... Thats a GOOD thing. Ever notice how are first gear is almost useless at the track ? Thats all that torque everybody is so high on. Once that k20 gets movin it should scoot right past an SS. *EDIT* If its not past it already.
Originally Posted by denny
Where talking about engines here and not the car itself. We all know that the Cobalts weakness is to put the power to the ground. When that problem gets fixed....the torque that everybody is so high on will leave the Blown K20 2-3 cars behind. Trust me you will see... I too am an EXhondaman and there is a reason why am an EX.... To each their own
I ran my Vtec Hybrid w/ 28psi for 40k miles... couple of blown head gaskets but only becuase I was too cheap to get it o-ringed
Manufacturers of parts(pistons, rods, block guard, Fuel management, etc..)? Engine type B18? 28 PSI what turbo was used? oh and how much money did you spend $$$$?
DC the LSJ was built for forced induction. Destroked Short strong Rods (2.0L) , Forged Crank, Piston design for cooling, Oil jets for every cylinder, 9.5 Compression ratio, SS valves, etc...etc... of course the engine is not gonna put out crazy horsepower without Forced induction its built for it.....built to take the pressure...stock bottom end and its already been proven to take 19 PSI. Take a Honda engine wich is built to be N/A with all out Horsepower (wich still makes less Torque then the LSJ without a Supercharger) and strap a M-62 supercharger on it and run it to 19 PSI and see what happens....
To each their own.
To each their own.
Originally Posted by TooManyCars
On a side note, the new SAE standards for determining horsepower from manfacturers engines has determined that Toyota and Honda to be liars on thier horsepower ratings.
Oscar
Oscar
Originally Posted by codyss
A 1995 Cobras 5.0 is far from high compression at 9:1, tell him to do it they need all the help they can get.
Yeah they do. 6-8 Pounds of boost is fine on those motors when they're stock. Anything over that is trouble though.
yea, look at any turbo kit for sale for a n/a motor with n/a compression. they give you limited gains because you can only run 6-8psi safely. anything after that you need to change the compression to around 9:1-10:1 and/or some serious tuning. you try slapping on a gt35r to a n/a motor with like 11:1 compression and run 25psi....haha
To each their own.
To each their own.
You answered my question thanx
For all those saying that GM can't build a good N/A 4 banger, anyone remember the 2.3 HO Twin Cam? 190 hp I think, and thats with no valve timing. No rediculous redline either, which means it actually had to have some torque to get that much hp too
and your source is?
Asians oversell horsepower
Toyota, Honda inflated claims of engine muscle; new tests force automakers to come clean with buyers.
By Jeff Plungis / Detroit News Washington Bureau
WASHINGTON -- After years of touting ever higher horsepower numbers to win new customers, Toyota Motor Corp., Honda Motor Co. and possibly other automakers are now backtracking on some of those claims.
Strict new tests developed by the industry's top engineering group are prompting the carmakers to roll back horsepower estimates on several key vehicles, including the Toyota Camry, America's best-selling car, and Honda's luxurious Acura RL.
For the 2006 model year, Toyota says its Camry equipped with a 3-liter V-6 engine generates 190 horsepower. In 2005, Toyota said the same car with the same engine had 210 horsepower.
The revised ratings comply with new Society of Automotive Engineers standards designed to eliminate subjective interpretation in establishing horsepower claims.
While Toyota and Honda are retesting their entire vehicle lineups, other automakers generally are retesting only cars and trucks with updated powertrains.
Honda is reducing horsepower ratings across its Acura brand. The flagship RL sedan will lose 10 horsepower, to 290 from 300. The popular MDX SUV will fall from a rating of 265 to 253. Less powerful models such as the Honda Civic will see smaller reductions.
"From what we've seen so far, this is going to affect the Japanese and the Europeans a lot more than the domestic manufacturers," said Mark Brueggemann, senior market analyst for Kelley Blue Book.
Brueggemann said engines have not changed, so car shoppers won't notice any drop-off in performance during test drives. But consumers look at horsepower when they're deciding which models to test drive and buy.
For example, the 190-horsepower Camry will compete against a new Hyundai Sonata that advertises 235 horses under the hood. "This could have a possible effect of eliminating a car from consideration," he said.
since they (honda/toyota) have adopted the new SAE testing the numbers for the rsx dropped from 210hp to 201hp. never said they lied about their #'s. they used the old SAE testing for the '05 rsx-s that's the reason it gave 210hp. the motor stayed the same for the '06 model but dropped 9hp due to the new testing. once again, they never lied about their hp ratings. they just adopted a new SAE test for their vehicles.
Oscar
Oscar
K20>> ecotec
http://forums.clubrsx.com/showthread.php?t=266655
Mod list...
Originally Posted by from link
CP PISTONS
CROWER RODS
COMETIC GASKET
GOLDEN EAGLE BLOCK GUARD
CLUCH MASTES 2 DISC
CUSTOM TURBO KIT
AEM AMS
1,600cc INJECTORS
WASTE GAGE 40 MM
BLOW OFF 50 MM
TO4/TO3 PRESICION TURBO
3'' CAT BACK CUSTOM MADE
PROFEC B TYPE S BOOST CONTROLER
EGT AND BOOST GREDDY GAUGE
THE BLOCK,THE HEAD, AND THE TRANNY IS STOCK, NO STROKER,NO DARTONS,NO HEAD POLISH ONLY A BLOCK GUARD, FULL INTERIOR AND DAILY DRIVEN!!!
CROWER RODS
COMETIC GASKET
CLUCH MASTES 2 DISC
CUSTOM TURBO KIT
AEM AMS
1,600cc INJECTORS
WASTE GAGE 40 MM
BLOW OFF 50 MM
Originally Posted by wasey13
K20>> ecotec
I can bring in some more examples, but that should take care of most disputes.
sorry could you post that again, i got lost reading about the 1000 hp stock block ecotec build book instructions, that the car manufacturer tells you how to do.
could you point me to the link from acura where they tell you how to build a 1000 hp 4 banger and all the part #'s listed individually? that's the example i would like
sorry could you post that again, i got lost reading about the 1400 hp stock block ecotec build book instructions, that the car manufacturer tells you how to do.
do you have a link to this 1400hp stock block ecotec? is this a daily driven vehicle? that acura is daily driven.
i meant to post 1000
it's in the gm build book.... and who cares about what car it's in now.. point being this setup can be put in any of our cobalts, and we got manufacturer support.. it's only a matter of time. you guys are comparing a car that's been out for 4 friggin years to one that has been out for about 10 months... don't be a hater man, just accept that honda isn't on top of the 4 banger market anymore. gm with saab have taken over
