ecu recalibration?
ecu recalibration?
ok with aftermarkit finaly starting to catch up i was wondering if anybody knows of a place who will do ecu work on the cobalt ss/sc i want to bump the boost with the bigger pully but the ecu wont let the car bost more than 14.5lbsl so anybody out there makein ecu reflash's or reprograming? thanks for any help.
Originally Posted by MarcS
You will also probably need to upgrade to a 3bar MAP sensor.
Originally Posted by djt81185
but they are aftercooled...that helps take a lot of the heat out
what you guys need to realize is that you have an eaton. You cant measure power by psi anymore really. An IC, cam, header, with a .8 smaller pulley than stock, and be running at the same psi as a fully stock GP. Its because they have an eaton type SC. PSI doesnt go up linearly like a turbo or centrifgual SC. As the car gets more efficient, the psi drops because the air isnt being "forced" in anymore, its flowing freely without restriction. 18 psi does NOT equal 18 psi across the board. You could be putting down more power with 10 psi if you have upgraded IC, cam, heads etc than if someone was running 18 psi on their stock car (obviously you dont want to do that because of kr).
Just something ive noticed on the boards.
As far as the PCM (its not ecu, you own an american car now
) Digital Horsepower is looking at making one if they can find someone in the Chicago area to let them test on their car. No sucess so far, but im sure someone will step up to the plate soon.
what the crap is a 3bar MAP senser? and where do i get one? and why do i need it?
The MAP sensor reads the vacuum or pressure in the manifold. This sensor provides key information for all Electromotive speed density based fuel injection systems, and is also used with the HPV-3B vacuum advance and boost retard. The sensor is available in 3 varieties for normally aspirated or boosted engines.
1 bar MAP sensor (for normally aspirated engines)
2 bar MAP sensor (for forced induction to 14.5 boost)
3 bar MAP sensor (for forced induction to 29.0 boost)
Manifold Absolute Pressure (MAP) Sensor
Originally Posted by clownhair
theres more than 3 different ones. I know for a fact there are 2.5 bar map sensors. The ones in our cars are supposedly 2.25.
If we have 2.5 bar sensors then there is no reason to upgrade unless someone plans to turbo and boost 22+ psi.
Twincharged
May 1, 2012 12:46 AM
