Engine Shutdown Please Help!!!
Old Jul 10, 2008 | 08:21 AM
schamsy's Avatar
Driving to work today, I was in 1st gear after pulling out of Mcdonalds I gunned it once going striaght. At about 5-6k RPMS the engine lost all power and sounded like it completly shut off, the gauges went to 0 and then all the sudden it was running again. Only mods are stage 2 with a 2.93 Pulley and a CAI.
Any thoughts?
Old Jul 10, 2008 | 08:22 AM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Did you just put that 2.93 on there?
Old Jul 10, 2008 | 08:28 AM
schamsy's Avatar
3 weeks ago. It has run great ever since, even at 6500-7000 in second gear, it never gave problems. I highly doubt the pulley made the engine shut down. It actually seemed like the computer shut it down...
Old Jul 10, 2008 | 08:30 AM
lewisb13's Avatar
I am not questioning the pulley. I just wondered if you were the same person who started a thread wanting a 2.93 just becuase noone else had a 2.93. Just need to know what kind of mentality Im working with here.
Did the car actually stall or did it stay running?
Old Jul 10, 2008 | 08:34 AM
BLAZIN07SS's Avatar
I'm too JDM for you
sounds like the car pulled a shitload of timing
Old Jul 10, 2008 | 08:38 AM
schamsy's Avatar
It felt like it completely stalled. I don't know if it was just the computer going into some limp mode or what. After the RPMS went to 0 for about 3 seconds they went to an idle and I had power again.
Weird that it would be pulling that much timing with my mods.... Clogged cat possibly????
Old Jul 10, 2008 | 08:39 AM
Altiery54's Avatar
dont think its the cat. how hot was it outside?
USMCFieldMP's Avatar
Rattlesnake Race Shop
If the computer went into Limp Mode... it would tell you. It flashes PWR REDUCED on the DIC.
Other than that... cars do weird things. Run some Lucas Fuel System cleaner through it and pretend it never happened.
Old Jul 10, 2008 | 08:42 AM
schamsy's Avatar
It was a comfortable 65 degrees outside, a little on the humid side no doubt.
Cool, nothing flashed or popped up on the DIC.
5 blocks later I had to try it again so I did. I went in first up to about 6-6500 rpm and had no problems. I did that twice before I ended up at work.
Old Jul 10, 2008 | 08:44 AM
Yeah. It was probably nothing major.
Old Jul 10, 2008 | 08:45 AM
Coop's Avatar
I have that same problem. When I first start the car in the morning or after it has been off for a while my car will just stumble big time if I get on the gas after starting it. If I let it run for a few minutes I do not have that problem.
Old Jul 10, 2008 | 08:51 AM
Jesus Christ... have you ever heard of letting the car warm up?
And having things like the A/C / Heater and Rear Defrost on will make the car idle hard and occasionally stumble.
Old Jul 10, 2008 | 08:54 AM
Coop's Avatar
When it is 90 degrees outside it shouldnt take long to warm up as you say. I have never had a car (owned all generations of camaros) that did this.
Old Jul 10, 2008 | 09:03 AM
Camaro doesn't equal Cobalt
Its a Supercharged 4-Cylinder... it takes time for the engine to get stability, especially on a 2.9.
Old Jul 10, 2008 | 09:09 AM
schamsy's Avatar
Still just wierd. No code no nothing, runs great 5 blocks later. I'm going to put the stage 2 pulley back on in case I have to end up taking it in for warranty work.
Old Jul 10, 2008 | 09:48 AM
Don't bother with the pulley. My dealership never even realized I had a different one on there.
Old Jul 10, 2008 | 10:04 AM
schamsy's Avatar
Should I put the stage 2 bolts back in? I painted my smoothflow pulley black, I have nates stainless steel bolts in now.
Old Jul 10, 2008 | 10:42 AM
Steel Bolts are fine. They are bolts. There is nothing to worry about. And I'm telling right now. The dealership isn't going to find anything wrong... so I wouldn't waste the time to take it there - like I did a million times.
Old Jul 10, 2008 | 12:49 PM
schamsy's Avatar
I talked to the dealer and they said that if it starts to happen frequently to take it there and they would hook up a data log to it to really see whats going on.
Old Jul 10, 2008 | 12:50 PM
When they hook that Datalog up... they'll see you've been taking it to Redline... and then, if they are that kind of dealership, they'll stop warrantying your car.
Old Jul 10, 2008 | 01:03 PM
schamsy's Avatar
They can see past log from my car? or just while I'm driving.
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
