Enthusiasts and vendors alike... header testing inside!
Old Sep 1, 2009 | 11:48 PM
  #551
hatrickstu's Avatar
dang man, sucks. keep us updated
Old Sep 1, 2009 | 11:51 PM
  #552
Deathscythe's Avatar
I will. A blown head gasket should have me down a couple weeks at the most. Nothing major. But it was plenty of white smoke. enough to blanket a 5 lane highway.
Old Sep 2, 2009 | 12:00 AM
  #553
Tennpenn83's Avatar
that's only a few hours worth of labor. might as well upgrade to arp headstuds while you're at it
p.s. when my headgasket blew, i found out it was not the headgasket at all, rather it was the stock head bolts failing, specifically on the 1-2 piston side. the headgasket actually looked fine.
keep posted on that, if you could?
Old Sep 2, 2009 | 12:10 AM
  #554
i will
Old Sep 2, 2009 | 12:32 AM
  #555
damien's Avatar
Wait, you don't have arp studs already? Was it a cometic gasket, how many miles?
Old Sep 2, 2009 | 06:35 AM
  #556
arp studs? yes
cometic head gasket? yes
I've heard of the resilience of the cometic head gaskets, which has me thinking now that it's probably something more serious. Gasket has about 7k miles on it.
Old Sep 2, 2009 | 08:34 AM
  #557
ralliartist's Avatar
In the words of Italian Joe, "I bet it's a sleeve."
Old Sep 2, 2009 | 08:37 AM
  #558
qwikredline's Avatar
sorry man too many dyno pulls?...
Old Sep 2, 2009 | 08:55 AM
  #559
Darkmanx's Avatar
The engine grenading on itself has to do with your right foot 90% of the time. Don't "whack-a-mole" the right pedal in second gear, and your motor will thank you. Mine didn't blow before I remodeled it, and it still holds strong now. Can't wait till I start to drop pulley sizes
You should have listend to this guy , See why i was telling you im not gonna build my engine until i blow up , because gm has the best engine build i have seen on a lsj to date . So why mess with it and have to build it twice. But i hope it is a head gasket and nothing major , i would hate to see you drop out the game for a while.l
Old Sep 2, 2009 | 10:05 AM
  #560
BennyHHR's Avatar
Nope, John... racin' too many dang handas.
Old Sep 2, 2009 | 10:50 AM
  #561
383_Stroker's Avatar
Oh snap.. sorry man
Old Sep 2, 2009 | 01:27 PM
  #562
well, if it is, then I am going with the darton sleeves. I chose not to the first time since they should have been able to handle the cylinder pressures. I might be wrong. Plus I've heard about the resilience of the cometic head gaskets.
It was already too late, I needed to build the engine anyway when I deployed the first time. I had the pistons for cyl. 1 and 2 pop on me. After looking at what caused such a great loss of power, the jbody header was on my car when it started smoking the first time. Both pistons were cracked on the side, and the rings were shot. The cylinder walls looked good, so we continued on with those. It's funny, Witt and WsFrazier were telling me that they were hoping for the best and would be watching. I guess my engine held on as long as it could. So to answer your question, this'll be the second time building it. But I'm actually going to have my hands in it, so I know it'll be right. All of the trouble I've had with the engine since I've gotten back was because of the person I trusted to build it.
Never again. It'll be right this time.
Last edited by Deathscythe; Sep 2, 2009 at 01:27 PM. Reason: Automerged Doublepost
Old Sep 2, 2009 | 01:35 PM
  #563
drew1991sf's Avatar
wat are ur build plans
Old Sep 2, 2009 | 01:49 PM
  #564
I know a few engine builders on here, so I am going to get some ideas, and do the research before I start buying things again. I got a little nest egg coming next month, I may just have to use it to get the car back running again.`
Old Sep 2, 2009 | 02:22 PM
  #565
i hate to agree with Darkmanx. Note 100% agreeing...
Old Sep 2, 2009 | 02:32 PM
  #566
noted. quik, I sent you a pm.
Old Sep 2, 2009 | 02:41 PM
  #567
Darkmanx's Avatar
whatever john.
Old Sep 2, 2009 | 06:00 PM
  #568
I'll look online tonight for the gm build book. See what I have to get for the rebirth.
I guess the worst thing is that I'm not even upset that this happened. It's just another chance for me to learn more about the car. Hands on experience.
just did a compression test on all cylinders. no. 1,3,and 4 all show around 200, where no. 2 is at 0. so at least i know where to start.
Last edited by Deathscythe; Sep 2, 2009 at 06:00 PM. Reason: Automerged Doublepost
Old Sep 2, 2009 | 06:01 PM
  #569
damien's Avatar
Sounds like a sleeve to me as well.
Old Sep 2, 2009 | 06:28 PM
  #570
domin8_gt's Avatar
Here you go Danew: http://gmtunersource.com/index.php/r...lsj-build-book
I want in on this. I'll help turn a few wrenches. This will be a learning experience for me. Feel free to do this at my house, if you can get it here.
Old Sep 3, 2009 | 01:12 AM
  #571
same exact sleeve I blew out. hmmmmm.......
Old Sep 3, 2009 | 04:22 AM
  #572
Zach06CobaltSC's Avatar
Sorry to hear about this bro, hopefully you won't be down to long. My cars currently getting built as we speak, should be done in a week or two I suspect. I cracked my 1st and 2nd piston, dunno how but it happened. It will be twice as strong once its done though =D.
Old Sep 3, 2009 | 06:31 AM
  #573
I'm looking forward to looking at the headgasket.
Old Sep 3, 2009 | 11:51 AM
  #574
Too much heat, or too much knock.. or to much N2O
Old Sep 3, 2009 | 01:55 PM
  #575
Mine popped the first time due to knock coming from the jbp header.
