Enthusiasts and vendors alike... header testing inside!
Old Aug 31, 2009 | 10:15 AM
  #526
Deathscythe's Avatar
I just need someone to send me a pacesetter, but I think the results will be similar to the vibrant, unless it's a 3" dp. The latest version has the 1.75" primaries and the construction doesn't look much different. So even if I don't, I could still pm you the results from the testing I've done with the vibrant, which should be a close match.
Old Aug 31, 2009 | 01:38 PM
  #527
ikeryder13's Avatar
hey bro when u gonna do the Clear Image Auto Combo?
Old Aug 31, 2009 | 01:49 PM
  #528
I am waiting for a piece of pipe to arrive from Dan Ferraro at CIA. When I ordered my header/dp combo, I made the mistake of ordering it to mate to a 2.5" exhaust. Dan was nice enough to send me the piece that I needed to complete my exhaust. I just have to send him back the piece that will be removed.
So I have the common 4-1 header, and hatrickstu has volunteered his to be used for this testing which is a 4-2-1. They will both be done within the next few weeks. We're going to try and make things quick, since the temps here are already starting to slowly drop.
Old Aug 31, 2009 | 01:55 PM
  #529
ikeryder13's Avatar
yeah i used to have the vibrant combo but i wanted to look into this especially since it can be catless to match with my hahn
Old Aug 31, 2009 | 01:57 PM
  #530
the vibrant works bro. It put down more than the stock header and 3" dp. The vibrant also had more timing on the table. But I feel the clear image is going to be best on my car.
Old Aug 31, 2009 | 01:58 PM
  #531
ikeryder13's Avatar
yeah i liked it it was just only 2.5 inch downpipe and i really wanted a 3"
Old Aug 31, 2009 | 02:03 PM
  #532
okay gotcha. Well, it's going on this week, probably wednesday after I get that piece.
Old Aug 31, 2009 | 02:04 PM
  #533
SlowBalt_06's Avatar
theres like 900 pages did you do the pacesetters armor coated header?
Old Aug 31, 2009 | 02:12 PM
  #534
there hasn't been one sent to me yet. I'm still waiting. And it's only 30 pages. Not that much. I am going to go through this again and clean up things for another thread. More information, less bs.
Old Aug 31, 2009 | 08:04 PM
  #535
domin8_gt's Avatar
Ah! Come on! It wouldn't be css.net without all the garbage. Leave it the same.
Old Aug 31, 2009 | 08:29 PM
  #536
lol I still need to clean things up some.
Old Aug 31, 2009 | 09:30 PM
  #537
Jrhdpaintball's Avatar
did ralli send u his header yet? the pacesetter header i was suppost to send you (thinking it had 1.75 primarys) only had 1.5 primarys. which is the same as ralli's... so if its easier on u and ralli, i can send you mine. might be a week or so tho, im still getting a DP ready for it
also still have CA V2 willing to contribute, all you have to do is say the word to take it off
Old Aug 31, 2009 | 10:12 PM
  #538
I'll send you a pm so we can get the ball moving. I want to get as many done this month as possible.
Old Sep 1, 2009 | 01:41 AM
  #539
SlowLSJ's Avatar
Originally Posted by mcrella.R.B.
Hey guys, I have a couple questions for everyone running the ZZP mid length header/dp combo.
How does the sound differ from the stock setup?
How much louder does it make the car (I don't want it to be too loud)?
Did you feel any noticeable gains in power after putting it on?
Thanks in advance.
i love it
Yes
yes and yes... make sure you get itt coated
http://www.youtube.com/watch?v=FTcAqh89E8I
http://www.youtube.com/watch?v=YP6Is...eature=related
i went from 13.8 1/4 to 13.4 from the header alone.....
Old Sep 1, 2009 | 01:44 AM
  #540
hatrickstu's Avatar
hey ds i measured the output on the 4-2-1, pretty sure its 2.5-2.25...
Old Sep 1, 2009 | 01:51 AM
  #541
twzted's Avatar
are you still looking for a CTI header/dp combo? 1.75 primaries 3" dp
Old Sep 1, 2009 | 06:20 AM
  #542
the size of the collector is 2.25? And what size is your dp? If it's not 3" then I might need you to send the whole thing. What size catback are your running? That would be a better question.
Sure, if you can get it to me rather quickly, then I'm up for it.
Last edited by Deathscythe; Sep 1, 2009 at 06:20 AM. Reason: Automerged Doublepost
Old Sep 1, 2009 | 11:54 AM
  #543
hatrickstu's Avatar
im running a 3 inch catback, the dp is 2.5 though. the collector may be 2.5OD, but the ID is very close to 2.25
Old Sep 1, 2009 | 12:15 PM
  #544
that would work great against the vibrant setup. Tell you what, do you have a sleeve for a 3" by chance? I still haven't welded on the 3" piece I am getting from cia, so I can send you mine for the time being until I get done with yours.
Sound good?
edit: The cia has a 2.5" exit.
Last edited by Deathscythe; Sep 1, 2009 at 12:15 PM. Reason: Automerged Doublepost
Old Sep 1, 2009 | 12:20 PM
  #545
hatrickstu's Avatar
sleeve where? ive cut the outlet flange off the DP and made it work with a 3 inch input i put on the hahn.
Old Sep 1, 2009 | 12:25 PM
  #546
that's fine. Does it have the ball and socket flange for the header/dp connection? If so, then I'll just send the header to you. Easier and less expensive to ship.
Old Sep 1, 2009 | 06:03 PM
  #547
hatrickstu's Avatar
oh yea, def still the same up there
Old Sep 1, 2009 | 11:17 PM
  #548
Guys, got some bad news. today, I had some bad juju happen with the car. It appears my headgasket has blown. She was spewing white smoke out the tailpipe, along with coolant I later found after I shut her down. She also had the scooby sound to her. My coolant reservoir was completely drained, but all my coolant hoses were still intact and secured. So I'm gonna tear the block apart this weekend, try to find out what the cause is of this. I also feel this is the reason why I had issues with the idle. I think that there was coolant getting to the number 2 cylinder, and at idle, the temperature wasn't enough to completely burn the coolant. But when it was moving, everything was fine.
Old Sep 1, 2009 | 11:25 PM
  #549
ouch man... if u were a little close id come by to help you with this... how far are you from baltimore?
Old Sep 1, 2009 | 11:38 PM
  #550
5 hours at the least.
