Excessive Clutch Pedal Play
Old Apr 19, 2010 | 11:50 AM
Bluelightning's Avatar
Got Bewst?
I bought an 06 SS/SC a few months ago with only 33,000km on it. I never really noticed up until i started driving it for a while the the clutch pedal has a couple inches of play in it before it starts to engage. I assume this isn't normal. The clutch works great. Doesn't slip or anything. Does the clutch just need to be bled or is something more major like a throw out bearing?
Old Apr 19, 2010 | 07:17 PM
erackSS's Avatar
idk man i get that from time to time with mine still trying to figure out whats going on
ive replaced the clutch master slave pressure plate and clutch disk
bugging the **** outta me
Old Apr 19, 2010 | 11:44 PM
Got Bewst?
Good to hear i'm not the only one haha. Anyone out there that has any advice or experience on this?
Old Apr 19, 2010 | 11:50 PM
mrbelvedere's Avatar
it needs bled out again
Old Apr 20, 2010 | 08:01 PM
Kennyspec's Avatar
needs...more.....bewst.
Old Apr 20, 2010 | 09:22 PM
Got Bewst?
Soon enough kenny. With a non slipping clutch... Sooo i found that if i pump the clutch really fast all the play goes away. But once i start using it normally again the couple inches of play comes back. Just some air in the system i would assume?
Old May 2, 2010 | 04:24 PM
55supercharged's Avatar
bump for answer as this is my current problem too.... if pump the clutch it works normal after dd it has play in it again as if it losses its spring so to speak.
Old May 2, 2010 | 04:56 PM
1fastSSBalt's Avatar
Why don't you try to bleed it and see what you get from that.
Old May 2, 2010 | 04:58 PM
Backdrift's Avatar
This.
If you have to pump the clutch to get pressure, you probably have air in the lines. Bleed it.
Old May 2, 2010 | 07:59 PM
how would i bleed it?
Originally Posted by Backdrift
This.
dont know how i would have air in the lines? me and paul (dainslaif) where doing some pulls because he was tunning me and it just lost its spring in the pedal..... there was nothing leaking,no clutch slipping,and all gears goe in and drive fine
ps stock tranny 50k miles
Last edited by 55supercharged; May 2, 2010 at 07:59 PM. Reason: Automerged Doublepost
Old May 2, 2010 | 11:38 PM
Backdrift's Avatar
There doesn't exactly have to by rhyme or reason for it. **** happens.
Having an air bubble in the lines will not effect how the tranny shifts. The clutch will not slip either, unless the clutch or flywheel are bad. Also, an air bubble wouldn't exist in leaking lines, because it would have....leaked out the lines.
Doing hard shifts during pulls could cause it. I can't explain how, but if you're rough on the clutch, it should go with out saying.
You wanted advice when you came in here, and it's been given. Not sure what else to tell you, unless you want us all to agree with you.
Old May 3, 2010 | 12:31 AM
was just a question on why it would have air in it.....no need to get smart about it.
anyway bump for info on how to bleed the air out
Old May 3, 2010 | 12:05 PM
Backdrift's Avatar
Haha, sorry man. I thought you were the OP. It pisses me off when the OP asks for advice, then starts telling people who are giving him the advice, that they're wrong.
That was my bad. I fail at reading names.
https://www.cobaltss.net/forums/problems-service-maintenance-69/bleeding-ss-sc-clutch-28120/
For clutch bleeding. Same thing as the brake lines.
Old May 3, 2010 | 12:36 PM
https://www.cobaltss.net/forums/showthread.php?t=28120
yeah its cool man..... And I found it but thanks... It just took me a while because css doesnt like when I search on my phone. I was gonn do it myself but ntb will chage me 50 bucks to do a whole brake fluid flush and since im already getting my tires mounted there might as well
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
