exedy clutch
The full face Exedy disc are only rated for like 200 ft/lbs. Most likely bad driving habbits with too much torque.
Could have just been a defect too, but Exedy usually has pretty high standards.
Hmmm. You posted in the LSJ section. I'll take it you own an LSJ. What's really odd is Exedy doesn't make a full face for the LSJ......
that was the oem replacement bc i was short on money after just buyin my house
I talked to a tech here at work. He said a failure like that could be a clutch defect or something wasn't aligned propely. Tranny, input shaft, imporperly cut flywheel, or anything else like that.
