Exhaust help and suggestions!!!
Old Apr 5, 2007 | 11:44 PM
hg_5's Avatar
I can have a local shop fabricate me an exhaust in any size piping from headers back for a total of 150 dlls. What do you guys recommend? Catless or high flow cat, What size exhaust should I get? my mods are the 2.7 inch pulley with the 60 lbs. and poly mounts. Is this a good price? what should i do?
Old Apr 6, 2007 | 12:01 AM
RBC's Avatar
RBC
If you going 2.5 don't bother changing from the whole cat-back. The SS/SC has a mandrel bent exhaust all the way back until it goes over the rear axle where in reduces down to 2.25. If you replace that section you will have a perfect 2.5 inch cat-back with out all the extra cost. Put a magnaflow muffler part #12256 for about $60 and use your stock tip. My total set up is going to cost $110 after tax. If anyone wants the info of the place on the internet that has it for $60 shipped let me know and I will post it.
Old Apr 6, 2007 | 12:09 PM
Ric's Avatar
Ric
Please post it.
Old Apr 6, 2007 | 12:27 PM
LopsidedJester's Avatar
2.5" on the stock catback is sorta untrue even before the axle. At the flange before the resonator, the openning is actually 2 1/8 inches. Also, where the stock exhaust is welded, it also goes down to about 2 1/8 and then 2.25 inches. I believe its best if you replace the whole thing. Plus, the stock resonator is restrictive, and can be replaced by a straightflow glasspack resonator for extra flow.
Old Apr 6, 2007 | 12:39 PM
Red2.4SS/SC's Avatar
dude you live in tx , theres one mandre bender in tx and its in houston , not in eagle pass, its gonna be *********CRUSH********** bent and in my opinion its gonna be a HUGE waste of money
a crush bent 3in exhaust is only as big as about a 2.34 -2.4 mandrel bent exhaust maybe even smaller
Last edited by Red2.4SS/SC; Apr 6, 2007 at 12:39 PM. Reason: Automerged Doublepost
Old Apr 6, 2007 | 01:12 PM
hg_5's Avatar
What makes you so sure is not mandrel bent?
Old Apr 6, 2007 | 04:35 PM
RBC's Avatar
RBC
no where did I see it go all the way down 2 1/8". I measured with the exhaust on and off the car and there was nothing close to 2 1/8. The stock resonator isn't really restrictive because it is really just a straight through muffler. The muffler is the true weak spot in the exhaust.
Old Apr 6, 2007 | 09:29 PM
maybe my 2.0 S/C has a different exhaust then. it is mainly 2.25", but there are tight overlapped spots of 2 1/8 inside the flange and at the weld where the pipe was made to fit inside the 2.25" pipe in the joining sections. Rulers don't lie. i'm talking about inside diameters though, if you're talking about 2.25 outside diameter, then i'm sorry about the miscommunication.
Also, I didn't check, but are you sure that the resonator doesn't have a plug in it also? lots of resonators have straight pipes, but have plugs in that straight pipe to force the air around and in the holes to muffle the sound. i should check mine, but i'm out of town at the moment.
Old Apr 6, 2007 | 11:04 PM
RBC's Avatar
RBC
Go to www.performancepeddler.com type 12256 in the search box. When you check out type ebaydiscount as the discount code and the the price will drop to $60 and some change. If the price does not go down e-mail him or click on the make and offer and offer $60.
If you add magnaflow muffler #10436 in the place of the resonator you will have the same setup as the magnaflow cat-back system.
Old Apr 9, 2007 | 08:23 AM
hg_5's Avatar
bump for some help??? how can i tell if an exhaust is mandrel bent?
Old Apr 9, 2007 | 08:36 AM
SlateFox's Avatar
do most shops do mandrel or do you have to specifically ask?
Old Apr 9, 2007 | 04:16 PM
PuSha050's Avatar
most regular muffler shops do crush bends...
performance shops usually do mandrel bends
Old Apr 25, 2007 | 10:26 PM
hg_5's Avatar
What is the difference in performance? or is it just a sound difference? Can i get a bigger crush bend exhaust to compensate for the smaller madrel bent?
Old Apr 27, 2007 | 12:16 AM
yeah, its all about the inner area, i'm sure a bigger crush bent exhaust would allow for good flow. Usually the best thing to do is to buy mandrel bends and straight pipes and weld them together. I'm not sure what shops do what, but i'd think its actually easier to buy pre-bent mandrel bent angled pipes and straight pipes, cut accordingly and weld together.
Old Apr 27, 2007 | 11:24 PM
hg_5's Avatar
thanks man ia appreciate your help
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
yellow dragon
Sep 28, 2015 09:49 PM
