exhaust question
exhaust question
i want the zzp 3in catback
Cobalt & Ion ---> ZZ Performance
i also want the vibrant header dp combo
Vibrant Stainless 4-2-1 Header - Over The Top Performance
just trying to make sure im understanding this correctly before i order. on the catback system i need to set my option to 2.5 dp flange since the vibrant dp has a 2.5 exit correct?
thanks!!
also im getting the catback first so i want it to bold to stock , and then getting the combo later when i have money for a tune to go with it.
thanks!!
thanks!!
thanks!!
Good luck to you.
is it possible to have a 3' dp with a 2.5'flange so it bolts to stock Or vibrant. cause i have a vibrant exhaust im going to install and i really would like to get a new DP on first
Yes, you should be using a 3in DP anyways, not a 2.5in, mated to a 2.5in flange if you want to use a 2.5in exhaust.
