exhaust question
Old Jun 10, 2011 | 10:00 PM
xTHExBOSSx46's Avatar
exhaust question
i want the zzp 3in catback
Cobalt & Ion ---> ZZ Performance
i also want the vibrant header dp combo
Vibrant Stainless 4-2-1 Header - Over The Top Performance
just trying to make sure im understanding this correctly before i order. on the catback system i need to set my option to 2.5 dp flange since the vibrant dp has a 2.5 exit correct?
thanks!!
also im getting the catback first so i want it to bold to stock , and then getting the combo later when i have money for a tune to go with it.
Old Jun 11, 2011 | 12:59 AM
D_Rob's Avatar
thanks!!
Yes, you want the 2.5 inch flange to mate to a 2.5 inch down pipe. Unless you have very high hp goals (as in possibly a TVS blower in your future) I think that a 3" exhaust is overkill. A 2.5" will do fine. Also, if by "bold to stock" you mean sound levels/tone, you would want to look into a exhaust system with "Touring" in the name, or else you will find they all range from louder than stock to significantly loud.
Good luck to you.
Old Jun 13, 2011 | 12:54 AM
Joemaster70's Avatar
is it possible to have a 3' dp with a 2.5'flange so it bolts to stock Or vibrant. cause i have a vibrant exhaust im going to install and i really would like to get a new DP on first
Old Jun 13, 2011 | 01:19 AM
Erick161's Avatar
Yes, you should be using a 3in DP anyways, not a 2.5in, mated to a 2.5in flange if you want to use a 2.5in exhaust.
Old Jun 13, 2011 | 11:15 AM
well the only reason i asked is the vibrant exhaust can bolt to a stock dp which im guessing is a 2.5" flange but the exhaust is 3" all the way
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
