Extra Quart of Oil, Big Problem or Not?
Old Oct 25, 2009 | 03:51 PM
gpro's Avatar
Just changed my oil and mistakenly put an extra quart in. I checked the dipstick after 5 quarts, and it was still low, so the 6th quart got it just right.
I just checked the manual and saw that it said 5, and I want to know if this is a big problem or not. Should I go and drain a quart right now, or just check the dipstick every once in a while and see if it goes really high and then go from there.
Old Oct 25, 2009 | 03:55 PM
fakameanrepresent's Avatar
from my research, too much oil than it is recommand will like flood your motor or something like that. i would drain some out just in case.
Old Oct 25, 2009 | 03:57 PM
matt_SS_205's Avatar
if i'm not mistaken doesn't the SS/SC take 6 quarts?
Old Oct 25, 2009 | 03:58 PM
Nato09's Avatar
pretty sure it takes 6 because my 2.2 takes 5.
Old Oct 25, 2009 | 03:59 PM
~Mike~'s Avatar
The ss/sc takes about 6.5 to be perfectly "full". I only ever use 6 tho 5 isn't enough
Old Oct 25, 2009 | 04:16 PM
HunterKiller89's Avatar
its a 6.4 quart pan IIRC. 5 quarts are for the L61/LAP/LE5/LNF (basically every other ecotec)
Old Oct 25, 2009 | 04:21 PM
Rambotk3's Avatar
Your fine! your almost where your suppose to be!
Old Oct 25, 2009 | 04:26 PM
Collin's SS's Avatar
put in 5.7L or 6 quarts
Old Oct 25, 2009 | 04:30 PM
JohnnySasakiMGS's Avatar
5.7 LITERS?! But yeah the SS/SC takes 6 quarts.
Old Oct 25, 2009 | 04:36 PM
bulletpound's Avatar
5.7 liters is 6 quarts....
Old Oct 25, 2009 | 04:49 PM
rukkee's Avatar
According to GM Service information the SS/SC take 6.3 Quarts of oil . I wish they would sticky this chart ....I've had to find it countless times to repost it.
Approximate Fluid Capacities
The following approximate capacities are given in English and metric conversions. See Fluid and Lubricant Recommendations for more information. All capacities are approximate. When adding, be sure to fill to the approximate level, as recommended in this manual. Recheck fluid level after filling.
Application
Specification
Metric
English
Cooling System
•2.0L L4 Engine Supercharged - RPO LSJ
5.7 liters
6.0 quarts
•2.2L L4 Engine - RPO L61
6.5 liters
6.8 quarts
•2.4L L4 Engine - RPO LE5
7.0 liters
7.4 quarts
Intercooler System 2.0L Engine - RPO LSJ
1.9 liters
2.0 quarts
Engine Oil With Filter
4.8 liters
5.0 quarts
6.0 liters
6.3 quarts
4.8 liters
5.0 quarts
Fuel Tank
51.1 liters
13.5 gallons
Transmission/Transaxle
•Transaxle, Automatic- Bottom Pan Removed 4T40-E
6.6 liters
7.0 quarts
•Dry
12.2 liters
12.9 quarts
•Complete Overhaul
9.0 liters
9.5 quarts
•Transaxle, Manual - Getrag 5 Speed
1.7 liters
1.8 quarts
•Transaxle, Manual - MU3
1.9 liters
2.0 quarts
Š 2009 General Motors Corporation. All rights reserved.
Old Oct 25, 2009 | 04:53 PM
samijo0703's Avatar
6-6.5 your good.
Old Oct 25, 2009 | 06:50 PM
leviticus88's Avatar
To answer the question tho,
Too much oil can be nearly as bad as too little on an engine.
I use 6.5 quarts.
Old Oct 25, 2009 | 11:40 PM
bolus's Avatar
The ecotec is good about pushing out extra oil out the crankcase vent at the top. At the track guys try to add extra oil to prevent starvation on turns but a little too much will just get pushed out. I've seen it happen several times. The problem on a street car like the cobalt is the crankcase vent leads back to the air intake for better emissions rather than a catch can. So that extra oil goes shooting back into your engine *doh*
Old Oct 26, 2009 | 01:25 PM
KillinKrullin's Avatar
i have an 07 and it actually says 7qt. if we put it up high enough and let it drain while i eat dinner. 7 qts is perfect after i let it idle for a few seconds. but for a quick oil change i put 6.5qt in
Old Oct 26, 2009 | 01:30 PM
cobaltguy889's Avatar
i'll put in 7 with my turbo lsj, with the oil lines and ****, i'd rather have a tid too much, than a tid to low
Old Oct 26, 2009 | 03:43 PM
Cigar Hero's Avatar
A couple bad things about too much oil, one is you may have oil coming out of places you don't want , like dip stick tube. If you have a breather sytem you'll be puking oil out there.
You'll get a lot of windage, LSJ have oil sprayers that cool the pistons but too much oil splashing up the cylniders is not so good it may cause the oil to foam-up. Too much oil in the pan will increase pan pressure.
Old Oct 26, 2009 | 04:00 PM
Mr. Lou's Avatar
Good info...
Old Oct 26, 2009 | 04:42 PM
More_Torque_More_HP's Avatar
Too much oil causes a condition called oil aeration. Basically the oil becomes foam. When this happens you loose the oil support between the crank and it's bearing and you loose the oil support on between the rod bearings and the rods. Usually the rods go first. The results are spun bearings and major engine damage. If you are going to "stress" your engine then running 1/2 quart low is way better than running 1/2 quart high.
06MetallicBalt
Jul 20, 2025 08:47 PM
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
