Factory Service Manual
Old Jul 22, 2005 | 01:02 PM
AutoX's Avatar
So I wanted to know who has or has access to a factory service manual. I want to know what one would cost and also what it shows in the manual about camber adjustment.
Old Jul 22, 2005 | 01:22 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
you should be able order this straight from the parts dept. at the dealer, if it available yet.
Old Jul 22, 2005 | 01:40 PM
JapEatr's Avatar
South Central *********
camber adjustment- remove lower strut bolt (keep top tight)
grind out the bolt hole opening pos or neg depending on what your specs read
replace lower bolt
loosen top bolt
slide strut in or out depending on what the measurement is
tighten both bolts
resweep for caster
done
repeat if necessary
Old Jul 22, 2005 | 03:28 PM
DARK AGE 53's Avatar
https://www.cobaltss.net/forums/general-cobalt-68/helms-service-manuals-your-cobalt-3944/
Old Jul 22, 2005 | 03:57 PM
OneLunG's Avatar
90$ for just the service manual
Old Jul 22, 2005 | 06:29 PM
$90 for what I've posted? There's 3000K pages in the Helms Manuals which means there's probably three volumes to the set.
Old Jul 22, 2005 | 07:41 PM
OneLunG's Avatar
Theres only 2. The 2nd Volume is for the Transmission though the 1st contains some info on it as well. The 1st manual is 90$
Old Jul 23, 2005 | 12:46 AM
AutoX's Avatar
so dark the link you posted is that for both manuals? or just the one? I will need both of them.
japeatr
did you read that out of the manual? or just blowing smoke? if not does it give range of what camber it can have?
Old Jul 23, 2005 | 02:40 AM
OneLunG's Avatar
www.helminc.com is where you get em from, but I think you have to have a dealer order them for you..
Old Jul 23, 2005 | 03:27 AM
zinner's Avatar
Moderator Alumni
I ordered mine through a dealer and I got the 2 manual set.
Old Jul 23, 2005 | 08:25 AM
It's a manual set, it would be the same as what Zinner has.
OneLunG, You can order them through Helms themselfs but it's cheaper to go through a dealer like Fred Beans Pontiac Buick GMC.
Old Jul 23, 2005 | 01:14 PM
Wolfman's Avatar
I would just go to the dealer its safer.
Old Jul 24, 2005 | 05:28 PM
ircmaxell's Avatar
Helm Inc is the OEM producer of all factory manuals, so it's buying the same exact thing, but cheaper...
Old Jul 24, 2005 | 06:06 PM
philco_3's Avatar
Proud Playstation 3 Owner
I'll wait to find it on Ebay in a year or so. Be just like buying my Cavalier book on there for $30.00
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
importkiller
Sep 30, 2015 07:18 PM
