Factory Service Manual
So I wanted to know who has or has access to a factory service manual. I want to know what one would cost and also what it shows in the manual about camber adjustment.
camber adjustment- remove lower strut bolt (keep top tight)
grind out the bolt hole opening pos or neg depending on what your specs read
replace lower bolt
loosen top bolt
slide strut in or out depending on what the measurement is
tighten both bolts
resweep for caster
done
repeat if necessary
replace lower bolt
loosen top bolt
tighten both bolts
resweep for caster
done
repeat if necessary
so dark the link you posted is that for both manuals? or just the one? I will need both of them.
japeatr
did you read that out of the manual? or just blowing smoke? if not does it give range of what camber it can have?
japeatr
www.helminc.com is where you get em from, but I think you have to have a dealer order them for you..
OneLunG, You can order them through Helms themselfs but it's cheaper to go through a dealer like Fred Beans Pontiac Buick GMC.
importkiller
Sep 30, 2015 07:18 PM
