fuel pressure regulator or safc 2
Old 01-20-2007, 11:11 PM
Rage915's Avatar
Question fuel pressure regulator or safc 2
do you guys know if we can uses safc on our cars? if not does anyone know if they make a fuel pressure regulator for us. im getting 60lbs inectors and i want to be able to adjust the fuel to get the right A/F ratio. can anyone help me with this? any info and feedback will be appreciated.
Old 01-20-2007, 11:33 PM
bluecobaltss06's Avatar
If you can find someone with HP Tuners they can adjust the tune in the computer and you don't have to worry about a different regulator
Old 01-20-2007, 11:53 PM
Rage915's Avatar
i think they'll charge me an ass load, i d rather do it myself with a dyno
Old 01-21-2007, 10:51 AM
2K5SS/SC?'s Avatar
The SAFC was tried on out cars, and it did not work. The PCM is too smart for it and overrode the SAFC in the end. You will need to buy HPTuners and a laptop to correctly tune your car. You can also purcase a tune for $100 (send in your PCM and they send it back) from a vendor to get you started, or borrow a tune from someone on here via HPT. An adjustable fuel pressure regulator is not an acceptable way to tune a car either. It's more for a fine adjustment to the fuel system.
Old 01-21-2007, 02:01 PM
Rage915's Avatar
so im pretty much fukd then!
also a bad idea to be borrowing tunes from other people, again the FPR is not to tune but to get the right mix of A/F, sorry if it came off like i wa going to use it to tune.
thanks for the info and feedback
Old 01-21-2007, 04:38 PM
2K5SS/SC?'s Avatar
I meant to use someone else's tune to get you started. You could also give TAG racecraft a call. They can do a mail order tune, that could be tailored on the safe side still until you get hooked up with HPT.
Old 01-21-2007, 05:15 PM
Moderator Alumni
zinner's Avatar
Better off finding a member with HPT near you in Texas and having them hook you up with a tune.
Old 01-21-2007, 05:41 PM
Rage915's Avatar
thats a downer, owelli guess
Sl0wbaltSS
11-21-2018 11:11 PM
hacadacalopolis
10-28-2015 06:09 PM
no_ss
10-18-2015 11:58 PM
DocSvensk
09-27-2015 02:24 PM
Adiaz1ss
09-26-2015 11:51 PM
Quick Reply: fuel pressure regulator or safc 2
