fuel pump size
Old May 21, 2007 | 09:54 PM
Area47's Avatar
Rent me! per hour
fuel pump size
not dimensions, the actual flow rate.
l/hr
gph, either one will work. or does anyone know? is it a great mystery? should i consult the great pumpkin, and Ms Cleo?
Old May 21, 2007 | 10:09 PM
Mikey851's Avatar
l/hr
Nyo Shugga', Ms Cleo dunt know about da grit fewl pumpkan.
Old May 21, 2007 | 10:32 PM
Area47's Avatar
Rent me! per hour
i'll admit it, i giggled
Old May 21, 2007 | 10:54 PM
Mikey851's Avatar
I know you said it outloud too didn't you . Anyways, back on topic. I don't know, but I bet either you or I could find out on Ecotecforum.com
Old May 22, 2007 | 12:25 PM
Area47's Avatar
Rent me! per hour
nothing. can't find a damn thing. found the pressure rating all over the damn place, but no actual measurement on gph or L/hr.
this makes the pigmy's cry
Old May 22, 2007 | 12:27 PM
RaineMan's Avatar
thinking about replacing it with a more highly flowing one? Might help solve our problems with #4 running lean.
Old May 22, 2007 | 03:38 PM
Mikey851's Avatar
Might as well just go return type if the pump is changed.
Old May 22, 2007 | 04:09 PM
Area47's Avatar
Rent me! per hour
not really, you can dial back the fuel with hp tuners if needed.
im trying to find the limit of the stock pump actuallt, which is why i need the flow numbers on it
Old May 22, 2007 | 04:40 PM
Mikey851's Avatar
I never said you couldn't make changes in HP Tuners, you have to make changes in the tune with every large change you make; I said while you are doing that you may as well go to a return system. Return systems are better and more easily expandable than returnless.
Old May 22, 2007 | 05:47 PM
Area47's Avatar
Rent me! per hour
now that would ruin all my fun!
i may just end up making a split fuel rail setup
Old May 22, 2007 | 07:13 PM
Mikey851's Avatar
That would be cool too. I was just sayin
Old May 22, 2007 | 07:15 PM
Area47's Avatar
Rent me! per hour
the fuel rail would be easier to make, but keeping the fuel line crap that is on the stock rail/line would have to be moved, and modded, blah blah blah
Old May 22, 2007 | 07:38 PM
Mikey851's Avatar
FYI, I believe (If you wanted to) someone on this site said there is a stock rail that will work from the 2.2L Ecotec out of the Cavi that is return type.
Old May 22, 2007 | 09:09 PM
blueta's Avatar
My buddies 03 cavi with a 2.2 has a return line. I want to check it out and see if it's similar
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
