Fuel setup
Old Oct 8, 2012 | 08:56 PM
silverblur06ss's Avatar
Fuel setup
Alright I need all you turbo guys opinion on a fuel setup/anything I missed for my build my build consists of:
diamond 9.5 compression
darton sleeves
k1 rods
cometic head gasket
supertech 78lb valve springs
stage 2 turbo cams
zzp 256et
3 inch vibrant exhaust
stage 4 spec clutch
spec flywheel
stage 1 zzp axels
255s on the front 235 rears
I think thats just about it I want a 500-550 hp mostly reliable street monster
Old Oct 8, 2012 | 08:59 PM
overboostedss's Avatar
drop in tank 255 pump. 80#s
Old Oct 8, 2012 | 09:05 PM
I have 80s do I need to run a return style system money really isnt an issue
Old Oct 8, 2012 | 09:06 PM
stonny9's Avatar
Op might want ID1000 and/or return style. At that level I would run some kind of e blend for added safety if it is available.
Also why not port the head also.
Old Oct 8, 2012 | 09:07 PM
my personal opinion is a return style is always worth it. It allows the fuel to constantly flow and keeps the temp of the fuel pump down. pump last longer
Old Oct 8, 2012 | 09:29 PM
I am going to port the head on my own and do larger valves from ottp also do I really need 1000s????
Old Oct 8, 2012 | 09:31 PM
you should be fine with 80s
JapEatr's Avatar
South Central *********
Deatchwerks DW300, RSFS
Old Oct 8, 2012 | 09:35 PM
"For gas builds, 80# injectors will take you to 600 WHP with raised fuel pressure" quote rite off the ZZP page
Old Oct 9, 2012 | 01:45 AM
I am going to be running e85
Old Oct 9, 2012 | 09:01 AM
mrbelvedere's Avatar
the stock pump is just as good if not better then a 255
you will need bigger injectors eventually
Old Oct 10, 2012 | 08:28 AM
where can I get ID1000s??
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
ThoR294
Oct 4, 2015 08:44 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
