fuel system install
Old Oct 18, 2008 | 09:57 PM
JCobalt's Avatar
fuel system install
i bought the ott return style fuel system a couple of weeks ago but it didnt come with any install directions.it seems pretty easy im just not sure about the in tank fuel pressure regulator removal part and where the lines to the tank are supposed to connect. I read the how to on how to do your own return style system but there is no pictures and not enough information. i could probably figure it out but i dont have a lot time to bring my car into the shop that i work at so i need to know how exactly where everything goes before i bring it into the shop. if anyone has any pics or can explain it, it would be greatly appreciated.
Old Oct 19, 2008 | 05:16 AM
theneelster's Avatar
Lego installation ftl. Yeah...it's not altogether crazy. You should be able to figure it out. Just swap the filter and the pump with the replacements then you have to remove the fuel rail valve to install the fitting without catching on fire. Good times!
Old Oct 19, 2008 | 10:53 AM
quadracer0387's Avatar
theres instructions on there site
bottom left of home page
Old Oct 19, 2008 | 11:19 AM
lsjwannabe's Avatar
http://ottperformance.com/Instructio...5b46ac83feed92
click on return style
Old Oct 20, 2008 | 02:32 PM
JCobalt's Avatar
i got the directions from the site but they didnt say how to modify the fuel sender. they just say replace the fuel sender with the modified fuel sender. i didnt get the option for the modified sender so i need to know wut to do
Old Oct 20, 2008 | 07:32 PM
Dainslaif's Avatar
You need to buy a new fuel pump or hook the stock one to it.
Old Oct 20, 2008 | 07:39 PM
hungryhip-ccp's Avatar
Old Oct 20, 2008 | 09:54 PM
JCobalt's Avatar
so just remove the regulator and put the stock pump back in
Old Oct 20, 2008 | 10:41 PM
Um...you need the replacement fuel sender or I'd figure the return system wouldn't work. Ask ott.
Old Oct 21, 2008 | 12:39 AM
Josh@ottp's Avatar
The modifications are pretty simple. I have some pics I can send you, pm me your email and I set you up with the pics and directions.
Old Oct 21, 2008 | 03:11 PM
JCobalt's Avatar
i sent u a pm
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
