fule rail problem
Old Apr 15, 2010 | 12:47 PM
scotch89's Avatar
fule rail problem
so a couple of week ago i installed my stage2. i went to loosen up that bolt that connects to the fuel rail, and i guess i didnt put enough pressure on the bottom bolt, and that pressed on pieace shot off. i put some gasket sealent on it and got it back together. now i threw a lean code. so i went to check my gaskets on my injectors and i went to do that bolt again. maybe 5 pounds of pressure and the pressed on pieace and it just started to spray fuel. so i said screw it and jb welded that thing on. im letting it cure right now and tonight. i was just seeing if anyone else had this problem?
Old Apr 15, 2010 | 12:54 PM
Rydis's Avatar
which bolt are you talking about? Im guessing the larger bolt that connects the smaller line to the rail? If so..you need to use two wrenches to loosen and tighen that bolt. Most likely you twisted the rail/broke when bolting it back on.
Old Apr 15, 2010 | 01:08 PM
scotch89's Avatar
so there a 21mm nut on top that threads into this piece that's a 24mm that is pressed on or somthing onto the fuel rail. when i first did this, i probely didnt put pressure on that bottom one to support it. wich made it weak and then just got to the point of loosening the tabs on the side to make it come off.
Old Apr 15, 2010 | 03:36 PM
SSfamilywagon's Avatar
I made the same mistake. Mine siezed on there and I slipped and broke it off.
I have a used rail for sale if you need it
Old Apr 15, 2010 | 04:43 PM
Rydis's Avatar
yeah, more then likely.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
