gapping AUTOLITE - Autolite Iridium XP Plug ?
Old Dec 4, 2008 | 06:37 PM
Sh0nuff's Avatar
Ok so you are not to gap the AUTOLITE - Autolite Iridium XP Plugs?
I noticed out of the box they are like 48 is this ok?
will the 06 ss/sc fully stock run good on them?
Anyone else running em?
Old Dec 4, 2008 | 06:41 PM
XM15's Avatar
0.048"?
You should run them tighter than that. I think stock for an SS is 0.040"
Old Dec 4, 2008 | 09:53 PM
Sh0nuff's Avatar
yeah but i was reading on here that you can't gap the iridums...
thats why im asking because i am about to get some..
after calling around my only choices around here right now are
autolite's the iridum or copper..
and acdelco iridum
so i go to change my plugs and guess what...
looks like i have 3 ngkR pfr6t's and 1 acdelco 12610767 iridium...
fkn idiots..
I swear who ever owned this car before me.....
Old Dec 4, 2008 | 09:55 PM
XM15's Avatar
You got the grab bag of plugs. lol
Old Dec 4, 2008 | 09:57 PM
ItalianJoe1's Avatar
Don't re-gap Irridums. Don't use shitty Autolites either. While I'm at it, don't waste your money on Irridium plugs at all. Get some NGK coppers, find a heat range that you like, play with gap until you get the best results. Rinse and repeat every other oil change.
Old Dec 4, 2008 | 10:43 PM
advise's Avatar
dont gap um, i got the same plugs and from stock they run alot smoother
Old Dec 4, 2008 | 11:41 PM
Sh0nuff's Avatar
i just got autolite copper's...
can't say it's real smooth but it is smoother and runs steady
Old Dec 5, 2008 | 12:11 AM
CruzinYellow's Avatar
Gap setting vs. Pully size
I have always had a problem with spark plugs myself to tell you the truth. There is always 1 out of the 4 that goes bad and I replace them all. This has happened 3 times in the last year. I had a set of Iridiums from NGK that were 1 step colder since my Cobalt is Stage 2 and my car didnt run like it should. Anyways I read earlier (and I'm trying to find the thread or website again) where it said showed that there were diffrent gap settings for diffrent size pullys. And if you ask most part stores they will tell you the stock gap setting and nothing else. Last time Advance Auto told me that the gap setting was .045 Now where I read earlier, it said that with a GM stage 2 pully the gap setting should be .040 (basically as you downsize your pully and gain in boost the gap goes down in .005 increments) This was all tested and found during the tuning process and dyno tests it should give you a pretty good idea about gap settings. Nevermind, after all that typing I remembered where I saw it.... Goto http://cobalt-addiction.com/performance.htm and click on the igniton tab and it shows the table with the gap settings and briefly explains it. I hope this somewhat helps.. BTW I have Autolite Coppers and they run really good compared to some I've had in the past!
Old Dec 9, 2008 | 12:51 PM
Staged07SS's Avatar
Administrator
Administrator
You can gap iridiums. People on hear say you can't, but you just have to be careful not to touch the tip. Do not put plugs in the SS/SC with a 0.048"gap it will run like ****. When I pulled my factory plugs which were NGK iridiums they were gapped at 0.035".
Old Dec 9, 2008 | 12:55 PM
D4u2s0t's Avatar
sparkplugs.com and you'll have them in 2 days, can get whatever you want.
but .048 is not the right gap.
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
