Gm performance clutch limits
Old Aug 29, 2011 | 08:46 PM
JCobalt's Avatar
Money is a little tight right now but I need a clutch to be able to bring the car to the track. I was wondering if anyone was running a gm performance clutch with with over 300 whp and torque. Does it slip when you launch the car or bring it to the track. I've run the spec stage 3 before and love the holding ability but right now I'm only running the stock one and it slips slightly on the street and really bad at the track. It slips to the point were I have to back off the throttle for it to stop slipping. I know The gm performance clutch is only rated to 300 hp but I'm hoping gm is just low balling the number.
Old Aug 29, 2011 | 08:49 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i'm on a big turbo kit with 25psi with this clutch. it will slip a tiny bit until it gets hot. then it's nice and tacky
Old Aug 29, 2011 | 09:08 PM
JCobalt's Avatar
I heard it's the same clutch as the stock lnf clutch and I know alot of those guys are easily over the 300 wheel marck so I figured it had to be better than what they advertise. Your probably making way more power than me with your setup and have minimal slip so I should be fine. Does it hold pretty good with repeated lauches?
Old Aug 29, 2011 | 09:10 PM
BLAZIN07SS's Avatar
I'm too JDM for you
I don't launch the car but back to back wot shifts it holds perfect. You shouldn't have a problem with it
Old Aug 29, 2011 | 09:13 PM
Bluelightning's Avatar
Got Bewst?
I asked which clutch to go with a little while back and got and majority of people said GMPP. Guys with TVS's were going to the track with no problems. I'm in the same boat as you so I picked a GMPP clutch up. Hope to install it within the next few weeks.
Old Aug 29, 2011 | 09:17 PM
JCobalt's Avatar
I know it should hold perfect on the street I'm just worried about repeated launches at the track. Seems like it should be good enough based off what you guys are saying.
Old Aug 29, 2011 | 09:28 PM
Got Bewst?
I hear ya. I'm a little worried myself. I run drag radials at the track so I hope it holds up. For $250 it's tough to say no to it lol
Old Aug 29, 2011 | 09:50 PM
JCobalt's Avatar
Yea it's almost worth wasting the time and money just to see if it works for 250
Old Aug 29, 2011 | 09:54 PM
Boosted05's Avatar
I have a ZZP S2, granted it's 3 times that of your GMPP one, it's rated to 300 ftlbs of torque. I'm just breaking my clutch in still though, 32 miles on it atm lol.
Old Aug 29, 2011 | 10:06 PM
JCobalt's Avatar
I replaced my first spec clutch after 45k miles when the throwout bearing broke and then I replaced the second spec clutch after like 30k miles with the stock one because it was jaming at high rpms and I was bending clutch rods and eventually shattered the inside of the master cylinder. I wanted to make sure it was the clutch so I replaced it with a new stock clutch that I had laying in my garage that came with my second motor.
Old Aug 29, 2011 | 10:08 PM
JCobalt's Avatar
Oh I run a findanza flywheel also, this clutch should fit right?
Old Aug 29, 2011 | 11:14 PM
Got Bewst?
Did you do your own clutch swaps?
Old Aug 29, 2011 | 11:20 PM
Boosted05's Avatar
any LSJ clutch will work with the fidanza, I have that in my car and DAMN it revs fast.
Old Aug 30, 2011 | 01:14 AM
ryansalazan's Avatar
i have one for sale if your interested. has 20k miles on it and about 75-80% life left on it. i just changed it because i wanted a clutch with no slip at all. other than that its perfect runs real smooth. im asking 100+shipping if interested let me know!
Old Aug 30, 2011 | 06:33 AM
JCobalt's Avatar
Yea I did the clutch swaps myself. I used to be a ford Lincoln mercury tech so I would just bring the car in the shop and change the clutch real quick when I had a Saturday off
Old Aug 31, 2011 | 10:50 PM
zrated89's Avatar
i ran a 13.1 @ 107 on street tires with the clutch with a 2.0 60' im currently strapping my tvs on and will be launching on slicks ill let you know if it holds lol
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
