GM Stage 3 and 100 octane mode question
alright well i stand corrected...i guess ive just never seen leaded race gas published anywhere before so i didnt think it was still around.....
but ya the shift light on by balt stage three wont come on so im wondering if theres something wrong with my car?? because ive been through 4 diff stage three pcus and still cant get it to come on whether at an idle (thanks for the tip, if i ever get it to work) or with the ignition on car off.....it sucks wish it would just WORK!
ya actually i went out just now after i left the last post to go drive around and i waited til my DIC said "low fuel" and the gauge was on the red..then went to my local race track and got some 110 octane fuel and added it in so im assuming with the gallon or half gallon or so of fuel left in my tank that puts me at around 103-105 octane.....should be enough to turn the 100 octane mode on 4 sure right......so then i went and drove around without the 100 octane mode on to get the leftover 93 out of the lines....after about 3-4 miles i pulled over shut my car off turned the ignition on w/ the engine off put my cruise on and held set for twenty seconds.....the shift light never came on and the DIC never showed anything...but when i took off i ran through the gears and it feels like it was running smoother and had more power in the power band rpm ranges...so maybe its on???and i just dont have a way of knowing it???? its a gm stage three prc says right on the back????
06 cobalt ss/sc 2.0 supercharged stage three, yellow and black gunpowder rims, dual pass intercooler w/heat exchange and 2nd surge tank, 60# injectors, step colder Autolite spark plugs, 3000 WATT audiopipe stereo system, lowered 1", 10% tint all the way around, custom color matching COBALT SS windshield badge, and custom paint matched yellow interior trim, custom paint matched brembo brakes, k&n typhoon CAI, 2.85" sc pully,17.5 lbs of boost at 7K, highflow downpipe, debadged of all chevy-ss-or supercharged badges and stickers except for third taillight lights up "SUPERCHARGED"
well not this gas...but thanks
sound to me like stage 3 was working the idle is where i can tell its on . ten hp is not a lot to feel when you drive run up on a car you have run before you will see you are faster then the base program. spray it you will see why i like it so much and its safe.i have a k&n intake header and 3inch down pipe with gmpp cat back . i have had that for a year and a half its all good . in the winter it mite through a lean code just be sure to bye good gas you be fine.
Ok listen man . Did you buy your cobalt new or used. If you bought your cobalt used it might be from Canada in which case the shift light does not come on when you activate the 100 octane mode.
Otherwise .put the key in the on position, then press the cruise control button on( make sure the light comes on for this button. Finally hold down the set button for 10-30 seconds .Then Simply turn the car on. do not tun the key backwards as this will reset the program. If the shift light does not come on then either you have a non GMS3 ECU or your car is Canadian.
Hope this helps man.
ya thats wat i was thinking was probly going on, thanks alot for the advice and the walk through...that is exactly wat i was doing to turn it on but i just wanted to make sure by talking to someone that knows wat theyre talkin about if there were any tips or tricks on it....but thanks guys....i guess im just gunna have to trust that its on???........and i bought my car used with 10K on it, was a gm buyback, turned out to be a shorted out wire in the truck so i bought it after they fixed it.
- - - -another point of discussion....wen i run it in 100 octane mode and with 100 octane racin gas i keep throwin codes for the o2 sensor bank1 after about ten-twenty min of runnin....any comments on that? i justr reset the code and its fine again and it only does it w 100 octane....Bad 02 sensor? or is it jus touchy???
06 cobalt ss/sc 2.0 supercharged stage three, yellow and black gunpowder rims, dual pass intercooler w/heat exchange and 2nd surge tank, 60# injectors, step colder Autolite spark plugs, 3000 WATT audiopipe stereo system, lowered 1", 10% tint all the way around, moonroof, custom color matching COBALT SS windshield badge, and custom paint matched yellow interior trim, custom paint matched brembo brakes, k&n typhoon CAI, 2.85" sc pully,17.5 lbs of boost at 7K, highflow 3" downpipe, debadged of all chevy-ss-or supercharged badges and stickers except for third taillight lights up "SUPERCHARGED", 10000K HID blue lights and fog lights
The PCM will not switch into high octane mode unless the PCM reads an octane reading of 100 or higher, so dont try it without race gas cause its pointless, its just like the SRT-4s with stage 2 w/toys.....Also i believe you can get away with a 2.8 setup on the stage 3 with a 50 shot. Just watch your bottle pressure, that plays a major role in how much nitrous is actually being injected.
Im telling you, you're using leaded gas.
have you actually measured the GM Stage 3 pulley ?? I have the GM Stage 3 pulley which has 76mm stamped on it which = 2.99in. If your 2.918 number is true thats awesome, but I'm having a hard time believing GM would put a pulley out with an un-true dimension.
So, just use the cruise to turn it on? I have a Canadian car so no way of telling if it is on, but I'll try it. And correct me if I'm wrong, the PCM doesn't detect the octane content of the fuel to keep the 100 Octane mode on, it looks for KR then shuts if off, if you can keep the KR to near zero it will stay on. This is from one of the Meth vendors. True, or not?
another road for discussion.....wat kind of plug/gap would u guys say is the best for a stage three scenario...like the one ive got???
Last edited by cobalt20yellow; Mar 31, 2009 at 06:00 PM. Reason: Automerged Doublepost
I run the BRK7's with about a .35 gap and nor problems
YEs is your car is canadian and you have GMS3 ECU you will not see the shift light come on. But it will be on. Kinda sucks for you man
i am using 110 octane...unleaded racing gas...trust me i am but i threw a code like twice...just wondered if that was normmal or maybe a f'd up o2 sensor??
I ran the BRK7's and it was missing at high rpm so I put the stockers back in and it runs nice and smooth. A few others have done the same.
Has anyone figured out how to determine if 100 Octane is on, for the cars with no shift light. Anyone with a light and an interceptor notice a difference in any readings? I tried mine with 50/50 meth mixtures, very little knock, (under 1.0 if that) can't tell if it stayed on.
Hello people,
I know that when you activate the 100 octane mode with the USA Cobalt SS/SC version, the shift light come on. But for us Canadians, what will tell me that it is activated? We don't have any shift lights... ahaaaaaa!
Oh and also just a "side" question: When you use the 100 octane mode, would this use LESS the 42 lbs injectors?? I mean... because the gaz has more octane, Im thinking that maybe the injectors have to use less gaz for the same AFR. Because I have the idea of puting a 2.85 or a 2.9 pulley instead of the 2.99" one by GM. Of course Im gonna use a wideband to see if I dont run too lean.
And anybody have ever used the 50 shot of nitrous with a smaller pulley?
Vince has done it again! He has taken GM's Stage 3 performance calibration and cracked it WIDE OPEN!
GM Stage 3 was released back in 2007, but never caught on due to the lack of tunability and unlivable lack of A/C. Thanks to Trifecta Performance, it now stands poised to be THE operating system to have for any and all LSJs!
Please read the FAQ below to learn more about this incredible breakthrough!!
Trifecta Stage 3 FAQ
What is Trifecta Stage 3?
Trifecta Stage 3 is a calibration that uses the GM Stage 3 Operating System as a base for producing custom tunes and adding new custom features.
The key factors that set Trifecta Stage 3 apart from GM Stage 3 are the following:
What if I don’t own HP Tuners? Is there a price difference for me?
Yes! There are currently four available configurations:
If you are purchasing the default GM tune with A/C unlocked, you will need the following parts:
Are the special GM Stage 3 features tunable by Trifecta?
The three main features of GM Stage 3 are the User-Adjustable Rev Limiter, High Octane Mode, and Nitrous algorithm. Please familiarize yourself with their basic functions before proceeding: Stage 3 Questions & Answers
GM RECOMMENDS USING A DYNOTUNE DRY NITROUS SYSTEM: Universal dry Nitrous oxide kit for cars and trucks. Nitrous system for all use with EFI cars and trucks. Our Nitrous Oxide system will add that extra boost needed. Buy Nitrous oxide direct from the manufacturer. - Universal Dry nitrous Oxide kits fo
Is Trifecta Stage 3 available for my car?
This list shows all GM Stage 3-capable vehicles (excluding the Ariel Atom), along with their current supported status through Trifecta:
ARIEL ATOM STAGE 3 IS FULLY SUPPORTED BY TRIFECTA, BUT NOT LISTED BECAUSE THEY DO NOT HAVE/NEED A/C
If you own a GM Stage 3 module for any of the unsupported vehicles in the above list, please contact trifectaperformance@gmofhouston.com for details on how YOU can help get that make/model year supported.
*Requires a special HP Tuners beta in order to access this model/year. I can provide this file, or you can email support@hptuners.com with “Request for Beta” in the subject line, and your HP Tuners serial in the body to acquire the very latest beta.
**HP Tuners support is dependent on the HP Tuners support staff taking the time to make a profile for this and adding it into a beta. The tune is available as HPT-compatible, but not necessarily supported. That is up to the guys @ HP Tuners.
Alright, I’m convinced, where do I sign up!?
If your car is among the list of Trifecta supported vehicles and you are interested in the Trifecta base or a Trifecta custom tune, you can ask your local Trifecta dealer for more information. A list of dealers can be found here:
Trifecta Performance Custom Tuning :: Dealers, Independent Tuners and Affiliates
If your car is among the list of HP Tuners supported vehicles and you want an *.hpt file sent to you, you can email trifectaperformance@gmofhouston.com with “Trifecta Stage 3” in the subject line, HP Tuners infolog attached, and at least your Name and City/State/Zip in the body.
Thanks!!
edit:
Cliff's Notes:
What is the GM Stage 3 Operating System?
You can read more about what GM Stage 3 is, what it does, and what parts it consists of in the Q & A session located here: Stage 3 Questions & Answers
Stage 3 Instructions: http://www.crateenginedepot.com/pdfs/s3ins.pdf
MANY OF THE ITEMS IN THE ABOVE Q & A SESSION ARE APPLICABLE TO TRIFECTA STAGE 3 SO PLEASE TAKE THE TIME TO GO THROUGH THE LINK BEFORE MOVING ON.
What is the difference between Trifecta Stage 3 and GM Stage 3?You can read more about what GM Stage 3 is, what it does, and what parts it consists of in the Q & A session located here: Stage 3 Questions & Answers
- Trifecta Stage 3 re-enables the Air Conditioning system that comes disabled by default from GM. This takes a previously “OFF-ROAD ONLY” calibration and puts it back on the street where it can be thoroughly enjoyed!
- Trifecta Stage 3 is available for sale as a file that you can flash to your cars current computer, rather than as a separate Powertrain Control Module that you must swap in place of your stock one. This eliminates much of the cost that you would typically incur in purchasing a PCM from GM.
- Unlike GM’s calibration, Trifecta offers compatibility with most commercially available tuning software like HP Tuners. This means that you, the end-user can change your OWN tune as YOU see fit.
- If you have 2 spare credits, are willing to purchase 2 credits from HP Tuners, or have your entire model year licensed, we can simply send you an *.HPT file.
- If you do not meet the above criteria, you can:
- Find a Trifecta dealer to flash the tune to your car then extract it with HP Tuners and copy your tune over to it yourself.
- Send us your PCM.
- If you decide to send us your PCM, we will copy your existing tune to the new operating system and send it back. Once you receive it, open up HP Tuners and be sure to do a "Read Entire". Save it with a file name that you would not easily confuse with your old tune on your hard drive.
- You may only use "Write Calibration" once you have done a "Write Entire". Accidentally flashing from one OS to the other using "Write Calibration" WILL irreversibly corrupt your PCM. You MUST do a "Write Entire" to flash between operating systems.
- You may use "Write Calibration" as long as you use the same tune file we sent you.
- TRIFECTA (HP TUNERS INACCESSIBLE): Uses the default tune from GM and enables A/C. For people who wish to stay at the GM Stage 3 power level but just want their A/C unlocked. This is the cheapest option.
- HP TUNERS ACCESSIBLE: Uses the default tune from GM and enables A/C. Trifecta won't be offering custom tunes for this option. Intended for individuals who already use HP Tuners and want to copy/paste their current tuning parameters over to the new operating system.
- HP TUNERS ACCESSIBLE + STAGE 3 FEATURE CUSTOMIZATION:: Same as above, but because HP Tuners doesn’t support them, we will perform any User Adj. rev limiter, HOM, and Nitrous customizations you request.
- TRIFECTA CUSTOM (HP TUNERS INACCESSIBLE): Custom Trifecta tune plus enabled A/C.For customers who want to install mods that are incompatible with the GMS3 tune, but do not or cannot tune themselves (e.g. - larger injectors, smaller pullies, methanol, TVS/Turbo swaps, etc).
- GM Stage 2 42# Injectors
- GM Stage 2 (77.9mm) or GM Stage 3 (76mm) pulley
- GM Stage 2 belt
- Open your Trifecta Stage 3 file in HP Tuners.
- Go to Compare --> Open Compare File, and open up your current tune file.
- Go to Compare --> View Comparison Log
- Right-click on each section and select Copy Over Differences until you have copied everything over to the new tune.
- Save and do a "Write Entire" to flash your new GM Stage 3 + A/C tune to your vehicle!
- User-Adjustable Rev Limiter
This feature allows you to adjust your rev limiter from 6500 up to 8000 rpms in 250rpm increments. If you feel the need to change the increment size from 250 to something else, we can adjust that for you!
PLEASE FOLLOW THE PRECAUTIONS REGARDING REVVING PAST 7000RPM LISTED IN THE Q&A LINK.
- High Octane Mode
This feature adds a predefined amount of spark to your current spark map. Because it is added to whatever timing you have already dialed into your tune, rather than being a separate spark table, this feature can be used with its default setting. We do offer customization of this feature for those who would like to fine tune it by adding more/less timing!
- Nitrous Algorithm
This feature pulls timing and adds fuel consistent with a 50 shot of nitrous. We have full control over the spark, fuel, and activation criteria (rpm, manifold pressure, & throttle position) for this feature. This means we can adjust it to accommodate for a bigger shot, or even zero out the spark and fuel tables to have this algorithm serve as an activator for anything you hook up to it!
e.g. – Hook it up to your meth pump and use it in conjunction with HOM! If your meth pump ever fails, the failsafe built into the HOM feature will keep your motor safe!
- 2007 Cobalt SS Supercharged: Trifecta + HP Tuners *
- 2006 Cobalt SS Supercharged: Trifecta + HP Tuners
- 2005 Cobalt SS Supercharged: Trifecta + HP Tuners
- 2007 Ion Redline: Trifecta + HP Tuners**
- 2006 Ion Redline: Trifecta + HP Tuners
- 2005 Ion Redline: Not Supported
- 2004 Ion Redline: Not Supported
Thanks!!
edit:
Cliff's Notes:
- You dont need to buy a PCM.
- You can put this tune on your stock PCM.
- If you dont want a Trifecta tune, you dont have to get one.
- You can just get the GM Stage 3 tune with A/C unlocked.
- You can tune on top of this with HP Tuners.
- Its cheaper to get the non-HP Tuners version.
- You CANT tune the HOM or Nitrous with HP Tuners. Only through Trifecta. This doesn't mean you have to get a full tune. You can ask for just those parameters and still use HP Tuners for the rest.
- You can buy this through any Trifecta dealer.
- For the HP Tuners version: You can have a Trifecta dealer flash the HP Tuners version to your car, then YOU extract it and copy your tuning parameters to it with HP Tuners
- You can get the HP Tuners file directly through me via email if you have 2 credits or your entire model year licensed.
- You can also send me your PCM to avoid spending any hp tuners credits.
