Gm Stage 3 pulley
Old Apr 13, 2009 | 06:56 PM
Pyros777's Avatar
Oh those part numbers are the little bits that match the GM stage 2 bolts. One is a socket and the other is screwdriver bit. Just in case you only have one or the other. Not sure which P/N is which though.
Old Apr 13, 2009 | 07:05 PM
07touringcoupe's Avatar
O ok thanks a lot. So about the 2.8? On the gm stg2 canned tune
Old Apr 13, 2009 | 08:59 PM
Pyros777's Avatar
2.8, even 2.90 are big no-nos on the GM S2 tune. You will hear of people who have done it with no apparent problems, but the facts are that your injectors and cooling system will be past their maximum capabilities and you will be walking a fine line.
If you want to play it safe I would go with a stage 3 pulley (2.99). Thats what I'm running, and once again here is the differnce between S2 and S3 pullies:
http://www.youtube.com/watch?v=xa0p19jFLYw
Old Apr 13, 2009 | 09:07 PM
So what psi of boost would I see on a 2.99 (stg3 pulley). And with a 2.8 I'd need 60s injectors and cooling mods? Also on that vid that balt that was stg3 was that only the pulley or was that the full stg3 pulley and reflash?
Old Apr 13, 2009 | 11:27 PM
ddsscobalt's Avatar
pyros--- how can you compare pullies when they are two different cars? one is a 2.2 sedan s/c and the other is the ss/sc ? thats not good information to be giving out imo...
Old Apr 13, 2009 | 11:45 PM
Pyros777's Avatar
This is true, but he was even with me before the S3 pulley so it is only logical. I'll see about switching the pulley out again and getting another run uploaded.
I'm not one to give out false information.
Old Apr 14, 2009 | 12:36 AM
ddsscobalt's Avatar
o i know i read alot of your posts i know your name, but i just watched the video and i got to questioning... wanted a little more explanation
Old Apr 14, 2009 | 12:48 AM
rukkee's Avatar
I have a stage 3 2.99 pulley and it is noticeable . I see around 16 -16.5 psi and it helps produce more boost in the lower rpm ranges VS a stage 2 pulley. The main reason i went with it was i didn't want to deal with the heat from a 2.8 or 2.9 , and the higher IDC's that go along with those pulleys. Also in the stage3 Q&A from GM they state that running the stg3 pulley on the stage 2 tune was fine for everyday driving.
Old Apr 14, 2009 | 08:45 AM
Iight that's what's up. On these cars. 1-1.5 psi extra is about what 10-15 whp? Or what?
Old Apr 14, 2009 | 10:57 AM
Pyros777's Avatar
GM claims 250hp for the S3 pulley vs 241hp for S2. Granted those are just numbers, but they do represent a claimed 4% increase in power any way you slice it.
The important part is that it is an increase across the entire powerband. I really wish I had a dyno sheet to prove it!
Old Apr 14, 2009 | 11:34 AM
  #36
O ok running that pulley on th gm stg2 tune isn't gonna make me run richer is it? It should lean me out right
Old Apr 14, 2009 | 11:40 AM
  #37
ddsscobalt's Avatar
where can you buy the stage 3 pulley?
Old Apr 14, 2009 | 12:31 PM
  #38
sput's Avatar
I'll sell you mine for $75.
Here's the link to the new ones for sale for $126.
http://www.crateenginedepot.com/stor...P1749C221.aspx
PM me if interested.
Old Apr 14, 2009 | 12:50 PM
  #39
SCcobaltSS's Avatar
http://www.smoothflowpulleys.com/
3.0 inch pulley... better deal.
Old Apr 14, 2009 | 02:11 PM
  #40
ddsscobalt's Avatar
yea if im gonna pay more than 50, im gonna get a 2.95 from smoothflow... They do custom sizes
Old Apr 14, 2009 | 02:14 PM
  #41
SCcobaltSS's Avatar
Exactly... Thats why I gave you the link... 125 hahahahahah that is rediculous.
Old Apr 14, 2009 | 02:23 PM
  #42
ddsscobalt's Avatar
yea haha... ive been looking at smoothflow... i was gonna get the 2.9 from ppl on the forum but two ppl have flaked on me and decided not to sell... i wanna do a 2.9 cuz i plan on getting the ottp h/e as soon as school is over and i return to full time work... but if no one sells me one ill get the 2.95 from smooth
Old Apr 14, 2009 | 05:51 PM
  #43
So its ok to run a 2.95 on a gm canned tune vs the 2.99 (gm stg3) pulley
Old Apr 14, 2009 | 07:03 PM
  #44
Pyros777's Avatar
Yes you'll be fine with that.
Old Apr 14, 2009 | 08:20 PM
  #45
ddsscobalt's Avatar
the 2.95 will put you right on that thin line between over doing it and being safe with the injectors and heat
Old Apr 14, 2009 | 09:02 PM
  #46
O oh so I would go up to a 2.96 or a 2.97. What psi of boost would get across the entire bandwidth?
Old Apr 14, 2009 | 11:45 PM
  #47
rukkee's Avatar
Yeah it is for a pulley, but it looks exactly like a regular stage 2 pulley unless you can read the number's on it . Most dealers don't have a clue how many MM a stage 2 or 3 pulley would be anyway but visibly they won't notice a thing.
Old Apr 15, 2009 | 01:01 AM
  #48
ddsscobalt's Avatar
okay good point, but with a smoothflow, its only 4 bolts, and you have to gms2 back on and you dont have to worry about a thing anyways
Old Apr 15, 2009 | 07:47 AM
  #49
O ok and to go any lower than a 2.95 I'd need cooling mods and bigger injectors?
And a tune right? Is a 2.96 or 2.97 ok to run off the gm canned tune right?
Last edited by 07touringcoupe; Apr 15, 2009 at 07:47 AM. Reason: Automerged Doublepost
Old Apr 15, 2009 | 08:06 AM
  #50
ddsscobalt's Avatar
ok if you go up by hundreths, your not gonna really notice... the stage 3 is a 2.99 or basically a 3.0... the 2.96 or 2.97 is just rediculous... go by halfs.. 3.0, 2.95, 2.9, 2.85, 2.8.
