Gm Stage 3 pulley
well those IAT2's aren't that bad with that size pulley.... do they drop pretty quick after a pull ?? Mine usually hit 150 and drop real fast down to 125 or so. they cont. to drop back down to my avg of 109-115.
oh i got ya .... well, a 2.9 is iffy. it's on the verge of being not safe when running it on a GM Stage Tune, because it maxes out the injectors. Now, if you have proper cooling mods and dont beat on your car everyday you will be ok with a 2.9 on a GM Tune.
i recently pruchased the GM Stage III PCM, and I must say combined with the GM Stage III pulley makes it a very nice setup. Safe, yet nice and powerful.
its not about how much fuel you have left. your factors to determine if it's safe are the injector pw/idc's, IAT2's along with your A/F ratio. many people run a 2.9 on the GM Stage Tune with no problems. just make sure you monitor evereything.
my interceptor displays and reads a/f. the gm stage tune commands anywhere from a 10.5-10.7 on avg. depending on year/version of the tune. my 07' gm stage tune commanded a 10.8 a/f ratio. my stage 3 tune commands a 11.4 a/f ratio.
theres a command a/f ratio selection. if you go to set up, it's under the list of parameters for selection. the interceptor reads the a/f ratio of the car through the cars PCM. widebands usually attach right to the downpipe to read a/f ratios.
i just got my interceptor so it might be a newer version of the software. there site doesnt even list command a/f ratio. mine is usually at 14.7 (Stoichiometric mixture) while cruising, but once i go wide open throttle the a/f ratio richens up. i didnt have to set anything up. i selected it under the list of parameters in my setup menu. i actually recorded last night when i was doing a wide open throttle run to see how my a/f ratio changes as i get in the upper rpms.
The commanded AFR is the AFR that your computer is being told to run.
The point of a wideband is to see the actual AFR, which the stock sensor cannot pick up.
Your computer could be commanding a 11.2 afr at WOT, but it may be actually only running 10.8...
The computer tries to calculate how far off the actual afr is from the commanded one, and adjust itself.. but it doesnt always work out.
Thats why in tuning, a wideband is very important, because you can dial in your computer to get it to the right afr.
You can however take the signal from your wideband and display it as a parameter, but without a wideband you can only view the commanded afr.
Last edited by ShortStack; Sep 16, 2009 at 02:36 PM. Reason: Automerged Doublepost
So when my interceptor guage is reading 11.4 at wide open throttle that means thats the a/f ratio my GM Stage 3 tune is commanding?
