GM STAGE 3 or ZZP ECU?
Which is better? I know the capabilities of the ZZP ECU but not much about the Stage 3.
I basically wanna know what the Stage 3 will do besides shut off the 02 sensors, raise the rpm limit, shut off a/c, ability to do 50 shot, and a 100 octane mode.
The zzp ecu does the following: Does the Stage 3 do any of this like the **** in bold
Speed limiter removed
Raised rev limiter to 7200
Altered fan turn on keeps the IC radiator cooler at all times
WOT fueling is revamped to provide a safe, flat air/fuel ratio at all RPMs
Codes removed for catalists allow high flow cats, no cats, or stock to work without setting codes (P0420)
Torque abuse modes are modified to eliminate bog during WOT
12 PSI boost limit is removed (after the 6,000 rpm or so where it bleeds off boost)
Timing revamped for increased power
MAF/MAP tables adjusted for running smaller pulleys
Idle hunting from installation of larger injectors improved
I heard that a stage 3 cobalt with a 50 shot can do 12.0 seconds... Thats crazy... I want to run a 2.9 w/ the stage 3 or the ZZP ecu and if i end up getting the zzp i hope to be in the mid 13's
Any info would be greatly appreciated...
I know there are a few guys on here running the ZZP pcm. From what I have heard your better off to go with the S3 pcm. But that is just what I have heard, I personally would rather get a dyno tune.
I actually think i've made up my mind... I'm gonna get a GM stage 3 ecu... basically because of the 50 shot.. and the ability to do 12.0 seconds.. I don't really wanna get a canned tune or anything... And don't really wanna do anything internal to the motor so i think the GM stage 3 would be good..
the stage 3 "kit" from crateenginedepot.com is definitely a better deal than just the computer, if you think you want a dual pass i say go with the kit and sell off the pulley maybe and get a nate pulley on ebay if you don't want the heavy 2.99" one they give you. Since its a GM product, i've seen the stage 3 pulley's sold for almost $100 on ebay, retails at $111-120
