Gm stages claims ...
Old Feb 22, 2006 | 10:14 PM
Jmc007's Avatar
Anyone notice that they claim ALMOST (less than) 0,3 second gain on a quarter mile ? That is waaaaay too low for a claimed 31 hp gain !!!
My guess is that a Bone Stock Cobalt SS + stage 1 will put down roughly 230 WHP on a Dynojet, not more.
Any thoughts ?
Old Feb 22, 2006 | 10:17 PM
memphisr24's Avatar
I'd say about 0.3 is about right. I look at it this way, for every 10hp is .1 in the 1/4 mile.
Old Feb 22, 2006 | 10:36 PM
MarcS's Avatar
The Stig
It says .7 for stage 2.
However:
You'll see 243 most likely with stage one, given a stock will typically dyno 210-212whp.
Old Feb 22, 2006 | 10:51 PM
SilverSS/SC's Avatar
I kinda would have to agree there . Given the average wp #'s , stg 1 should be solidly in the 240-250 wp range for most people ....if the rated clains hold up . They underrate everything else and the stock tune is so restricting .
GM Stage 1 plus a mafT to fine tune a 2.8 pulley should be the magic till the aftermaket can tune the pcm's .
Old Feb 23, 2006 | 01:48 AM
zinner's Avatar
Moderator Alumni
I ordered stage 2 and I have a before dyno, with my exhaust and the stock pulley
I will go to the dyno shop and do another dyno don't worry.
Old Apr 7, 2006 | 10:14 PM
Jmc007's Avatar
Zinner any results ?
Old Apr 7, 2006 | 10:34 PM
mi6_'s Avatar
A couple of things.
First, I don't think that the kits are necessarily underrated. Just because the car may be, doesn't mean the kits definately are.
Second, stage 1 may only increase peak HP in the upper RPM band, while stage 2 with the pulley likely will increase power over the entire RPM band.
Just my thoughts.
Old Apr 7, 2006 | 10:54 PM
TXRLU's Avatar
Will be interesting to see a graph of the dyno. I'm guessing peak HP will be observed past the 6500RPM rev limiter that's on the car now.
Old Apr 8, 2006 | 07:05 AM
Originally Posted by mi6_
A couple of things.
First, I don't think that the kits are necessarily underrated. Just because the car may be, doesn't mean the kits definately are..
When they say 241(???) hp for the stage 2 kit , that is going off the grossly underrated stock 205 hp figure . Anywhere GM lists a total advertised power # with the either stg 1 or 2 , they have to go from 205/200 , hence underrated . Even there dyno graphs are skewed to show that .
Old Apr 8, 2006 | 08:46 AM
Brian MP5T's Avatar
0.3 seconds on the 1/4 takes HP.. Sounds about correct..
RaginChopsuey
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
