GM's shortcomings
Old Mar 9, 2007 | 03:29 PM
Formula96's Avatar
GM's shortcomings
I wonder whose idea it was to throw 12 psi on a 2900 pound car and shortin the crap out of the first gear. What was the point of that? So once you burn through first gear, spinning no matter how much throttle you give the car, you get to shift into second and compleatly fall out of the powerband...
Now if i had a stock 7K revlimiter, i would be able to take first a little higher so i might actually shift into a little bit of boost...
I am not flaming gm at all, I love my cobalt, i just wish first wasnt so short.
Old Mar 9, 2007 | 03:34 PM
NinjaHampster's Avatar
join the club
Old Mar 9, 2007 | 03:35 PM
Ryuu600's Avatar
Strange I never spin first. Guess that's because I feather the clutch rather than dump it. I do see your point though. Reminds me of the last Jeep I had. Insane gear ratio and stupid first gear, if you weren't climbing the face of Everest without a winch it was completely useless.
Old Mar 9, 2007 | 03:38 PM
RaineMan's Avatar
Get stage 2... your first gear worries will be gone.
I don't see why the car's didn't come like this stock... it's way better than the stock tune in terms of drivability.
95cobra68camaro's Avatar
get a tune, i didit and it was the best thing i ever did for my 07' raising the limiter to 7200 solved all my powerbadn problems. although, the short 1st is a lil bit of a problem ur right.
Old Mar 9, 2007 | 03:40 PM
shabodah's Avatar
Try driving a manual trans 1 ton turbo Diesel. You got till almost 5 mph till you have shift.
Formula96's Avatar
well i might have allready changed my stock redline to 7k...
Old Mar 9, 2007 | 04:32 PM
bc3tech's Avatar
hptune = 7k = problem solved.
Old Mar 9, 2007 | 04:59 PM
mezzanno's Avatar
first gear still is too short though even with a raised limiter. If gm only would have used a more sensible first gear say 3.2 : 1, this car would have been capable of 13's stock.
Old Mar 9, 2007 | 05:54 PM
Formula96's Avatar
my tires are bald, so i figure 235-40-18 BFG G-Force Sports and an ingalls torgue dampner... maybe fix the problem.
Old Mar 9, 2007 | 06:01 PM
blackngold20's Avatar
Use Hp Tuners and tune your boost down in 1st gear
Old Mar 9, 2007 | 06:11 PM
Formula96's Avatar
if i still have traction problems after the tires and the torque damperner, then i will turn the boost down... not happily though, i would rather just have traction with my full power.
Old Mar 9, 2007 | 06:20 PM
0redline6's Avatar
as would every one else on a high powered FWD car.. but it doesnt usually work out that way.. and turning down the bost in 1st gear doesnt effect your 1/4 times really at all cuz you hook right the f**k an go.. not spin
Old Mar 9, 2007 | 06:25 PM
SuperCobaltSS's Avatar
Yea i agree!!
Old Mar 9, 2007 | 06:33 PM
joeworkstoohard's Avatar
ehhh, depends how you look at it, i'm guessing that the first gear is as it is to make the other 3 follow in logical order. the 4.05 is the biggest part of the problem, but i feel that if it had the 3.91 from the 2.4 and the 2.4 had the 4.05.... the SS/SC wouldn't pull away from the 2.4 like it does.
Old Mar 9, 2007 | 06:45 PM
spaz's Avatar
mine spins in 1st second and if there is any water on the road in third hahahaha
fwd sucks.
Old Mar 9, 2007 | 10:18 PM
You're right...that being the purpose for making a higher end model. Why would would they design the ss/na to be the same as an sc....
soundjunky
Oct 3, 2014 10:56 AM
oldun
Nov 1, 2008 08:01 AM
Zoidborg
Tuning
18
Aug 6, 2008 07:35 PM
boostbalt
Jul 30, 2007 02:07 AM
